Old 10th September 2009, 03:00 PM   #1
room237 is offline room237  United Kingdom
Default continuous and peak
Can anybody explain to me if i have this correct. I have a Yamaha EMX88s which had problems with clipping. Both the Behringer B215 passive speakers being used blew. I purchased these speakers as they were rated at 600watts and the the system i was using them with is rated at 400 watts if two speakers are used and 800 watts max if four speakers are connected.
I think i have found the reason why both speakers blew. The speakers are rated at 150 watts continous and 600 watts peak!! So i guess i am a doughnut and read this wrong. I have since purchased two Yamaha speakers matched to the amp which i should have done in the first place. I am in the process of replacing the blown woofers. But is this the reason why these speakers blew because they were being driven hard and were overloaded.
Thank you in advance
Old 10th September 2009, 10:50 PM   #2
http://sound.westhost.com/tweeters.htm
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 10th September 2009, 11:48 PM   #3
Luke352 is offline Luke352  Australia
Send a message via MSN to Luke352
Have a read of this> http://www.zedaudiocorp.com/Technica...r-Clipping.htm
Old 10th September 2009, 11:59 PM   #4
Oh if your wondering who that Zed guy is you can read his history here http://www.zedaudiocorp.com/aboutus.html it makes an interesting read actually.
Old 11th September 2009, 03:25 AM   #5
just another
wintermute's Avatar
when clipping is involved speaker and amp power ratings start to be a bit meaningless.... Even if you have a speaker rated at 100W and an amp rated at say 60W if you clip it, you will likely blow the speaker. The clipped waveform looks more like DC to the speaker than a normal signal, speakers are not designed to work with DC!
In a lot of respects having an amp with much higher power rating than the speakers is less of a problem than having an amp with a lower power rating than the speakers, in that you are much less likely to run into clipping.
However obviously if you crank it too much the speakers will blow (even without clipping) if the difference in power is big enough.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 11th September 2009, 03:44 AM   #6
prickears's Avatar
If you love loud, buy party speakers, they love it!
If you love music, buy Hi-Fi, and go easy on the throttle!
Regards, Mick.
Old 11th September 2009, 03:53 AM   #7
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Regards, Mick.
Or go high efficiency and enjoy both
To the original poster, I would ignore "peak" power ratings.
Jim J.
Old 11th September 2009, 03:55 AM   #8
prickears's Avatar
Amen.
Old 11th September 2009, 10:07 AM   #9
Thank you for the advice and the links..
200V peak to peak @25MHz ketan Parts 1 8th June 2008 03:21 AM
Pre Outs and peak-to-peak ? CheekyMonkeyVZi Car Audio 7 12th December 2006 08:30 AM
Need 25mmx7mm continuous sliders tocs100 Parts 2 3rd December 2005 12:13 PM
continuous outlogging Sylver300B Forum Problems 2 19th May 2005 09:11 PM
estimating max continuous spl of a speaker tech.knockout Multi-Way 4 30th March 2004 01:01 AM
Page generated in 0.15060 seconds (54.87% PHP - 45.13% MySQL) with 10 queries
