Looking for a cheap compression driver (for example mrd-80)
Hi to everybody.
I'm writing there because i want to know if you have tried a very cheap compression driver. I'm looking for something that could reproduce the frequencies between 3000-4000hz to 20000hz, with a good sensibility (about 105dB) and with a termal power of at least 40-50watt.
I would prefer driver with a sweet sound.
I have found these items:
monacor (img stage line) mrd-80 (17.90€)
monacor (img stage line) mrd-90n (29.90€)
Does someone has tried these drivers?
thank you!
:spin::spin::spin:
Ex-Moderator R.I.P.
Joined 2005
http://www.europe-audio.com/Product.asp?Product_ID=2706
Remember that even if you find a good cheap driver, you still need the horn, which cost money too
New Beyma http://www.beyma.de/fileadmin/seiten/download/pdf/Beyma_professional/2007-M_rz-SMC2012N_1_.pdf
Aschenbach sells it at 48EUR
May easily be improved by adding round edges at mouth
Frustration
Just a few days ago I found a big waveguide/horn, but cant find it again
It was the kind with rounded bottom/top and plane sides, made of plastic
Maybe not the best, but I was impressed by the size and it looked real good, and cheap
If someone know about it, please tell
I remember I saw it together with very cheap screw mount compression drivers
Ex-Moderator R.I.P.
Joined 2005
Frustration
Looks like it could be a Zomax H-1575
But the supplier?:confused:
Frustration
the horn is not a problem, because i will create it in wood... :D
the beyma looks great... :)
for the big horn i never saw something similarar... i'm sorry... :(
Ex-Moderator R.I.P.
Joined 2005
Yeah, I would too, if I had the time, but maybe some day
Just found the waveguide I couldnt find again
Doesnt it look nice
And its cheap
Measures 465(410) x 245(195)mm
Listed as Mcgee HL-1018
Selenium offers a good "bang for the buck." Selenium D220ti is about 30 euros right? But if you're going to go to the trouble of building a horn, and you don't need output below 2khz, get the best compression driver for that range:
The BMS 4540ND. Shouldn't be more than 60 euros or so.
I'm sorry, where i can find this driver for 60euros?
ps happy new year!!!
:D
