Old 10th September 2009, 08:10 AM   #1
hasaudio.co.nz's Avatar
Default Are the SEAS ODINS really that bad?
Ive been looking at building a ref speaker for each speaker brand i supply. Odin for seas was the plan but ive seen a few bad reports regarding it. Has any1 here had any experience with these speakers? And what are your thoughts?
Hasaudio Speaker Components
Old 10th September 2009, 08:31 AM   #2
StigErik's Avatar
Take a look at Seas' own measurement of the speaker (the MK 3 version).
http://www.seas.no/images/stories/di...easurement.pdf
It should sound a bit too midrange-focused, dont you think?
The main problem with this kit is that the XO dont correct the baffle step quite enough. The series coil should be 1.5 mH, not 1.0 mH, but then the speaker would get 2-3 dB lower sensivity. I think they traded sensitivity for an incorrect tonal balance.
Old 10th September 2009, 09:01 AM   #3
nicoch58's Avatar
better look at Troel Gravensen ,very fine xover
Old 10th September 2009, 09:08 AM   #4
Has troels designed a xo for this speaker?
Old 10th September 2009, 09:21 AM   #5
jerome69's Avatar
Short Thor build
Use this crossover instead.
Old 10th September 2009, 10:50 AM   #6
nicoch58's Avatar
troels have a ton of seas project , better then Odin that is quite old ..
taste of music ....from troels:
"Before going into details, a little on the sound. To my ears the sound from these nextel coated drivers fall between the SEAS Prestige CA and EXCEL magnesium drivers. This may suggest sound quality inferior to the magnesium cones. It isn't. It's as good as the magnesium cones, only different due to improved responsiveness. I don't think they beat the magnesium cones in terms of neutrality, but these Nextel coated paper cones provide a very neutral, yet vivid sound. The best of both worlds? Well, only your ears can tell."
hope this helps
Old 10th September 2009, 11:47 AM   #7
gainphile's Avatar
With massive metal resonance at 5kHz and xo frequency of 2.2khz, the harmonics distortion of W18 would be massive. Such driver should be used under 1kHz or perhaps 1.5kHz with very steep xo and deep notch (active xo).
Perhaps this is what the builders are hearing.
btw. I have Seas L21 with nearly similiar peak, only about 400Hz difference, which is at 4.6kHz compared to W18.
I cross it actively at 1.5kHz and put in very deep, high-Q notch (18db) and the peaks are still there. It is audible.
http://gainphile.blogspot.com
Old 10th September 2009, 11:55 AM   #8
jerome69's Avatar
We should temperate our judgments.
Magnesium driver have the best midrange I have heard... I never heard a such better cone. But you should remove the resonance cone carefully.
Old 10th September 2009, 05:53 PM   #9
nicoch58's Avatar
X-ray speakers , but musical ??
when xover the tw so low in critial range with hi order ,the best midrange are lost HIMO
Old 10th September 2009, 09:08 PM   #10
jerome69's Avatar
You will be very surprised
Seas 27TDFC H1189 vs Seas 27TFFC H881 ermes Multi-Way 4 19th April 2011 01:20 PM
chooseing Seas Cygnet or others seas kits juanito Multi-Way 0 20th July 2009 12:27 PM
Wanted: Seas W17EX001, Usher 8945P, Seas CA18, or somewhat similar mid-woofer. Spasticteapot Swap Meet 2 7th March 2007 04:06 PM
Sealed Odins + sub? (or other recommendations welcome!) Virtalahde Multi-Way 3 2nd May 2006 03:21 PM
Seas Excel W26 compaired to Seas L26 (10") harruharru Subwoofers 9 11th March 2005 09:47 PM
Page generated in 0.20793 seconds (49.40% PHP - 50.60% MySQL) with 10 queries
