#41 | |
After I finish the car I believe I am going to resurrect my home theater unity project. I think that the things that make the Unity so special could be well suited to a surround sound system, where timing is so important. At the very least, the extra intelligibility will improve dialog in movies. And anyways, I got the Summas upstairs, and my home theater speakers are from Costco. I *gotta* rectify that soon
#42 | |
Oh yea and some subs.In my mind its not tubes versus transitors, its crossover versus non. Virtually all transitor amps are AB and thats a recipe for disaster at low level zero crossings which is exactly where things are the most audible. |
#43 |
Dr. Geddes, just wanted to say I appreciate you "dropping some knowledge" where and there on the internet. Just my little experience experimenting with some of your ideas and suggestions has really convinced me that you are preaching the truth. While I don't own any of your products at the current time, I know my next home system will have your products in it.
#44 |
Are you referring to crossover distortion? And if so, would you say that high sensitivity speakers make such things more audible? Maybe could be some form of harshness?
#45 | |
Yes, crossover distortion, and yes I do believe that high efficiency speakers will accentuate this problem. You are very perceptive. I believe that what audiophiles call "lack of detail" could well be related to this since "detail" means low level signals and the lower the level of the signal the more it is affected by crossover distortion. In my studies of the audibility of distortion crossover distortion was, by far, the most audible and insidious. So much so that it is all I look for in an amp. Curiuosly, the way amps are measured and rated this problem won't show up. |
#46 |
How would one measure crossover distortion? Great thread!, BTW.
"If we knew what it was we were doing, it would not be called research, would it?" A. Einstein |
#47 |
If you look at the spectrun of a 1kHz tone as the signal level is reduced the harmonics should fall with level or stay the same. If they grow, or even worse, the number of orders increases (which is very common) as the signal is reduced then there is crossover distortion and you should throw the amp away. You can't look at THD VS level, because at low signal levels all you are measureing is noise. In a good amp, like I have, the harmonics of the signal should disappear into the noise floor as the signal level is reduced. There are actually ways to measure this using a sychonous signal that will measure below the amps noise floor. This is very revealing.
#48 | |
Rgs, JLH
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way! |
#49 |
Interesting. The only way I knew to get around the problem of crossover distortion and high efficiency speakers was to use a class A amp.
#50 | |
| I learned A lesson in Grounding today! | Zero Cool | Solid State | 2 | 29th December 2007 12:06 PM |
| what have learned....+ and - | timothy | Full Range | 3 | 9th October 2005 07:38 PM |
| Some learned advice needed. Pretty please. | G | Digital Source | 1 | 13th April 2005 05:33 AM |
| Learned a lesson today | Ralph | Tubes / Valves | 9 | 18th December 2003 06:35 PM |
| Page generated in 0.13917 seconds (81.70% PHP - 18.30% MySQL) with 11 queries |
