#11 | |
Objectively, this is A Good Thing, because a consistent response off axis improves the soundstaging of a loudspeaker. I'll throw in some subjective commentary too... |
#12 |
The roundover on The HOMster really made an improvement. But what if we filled the horn with foam? And while we're at it, why don't we add a vertical roundover? So I chopped up about fifty cents worth of PVC pipe, and added about a dollar worth of 30 ppi reticulated foam inside the horn. Geddes uses reticulated foam to damp the sound which doesn't travel down the axis of the horn. The way that the foam works is that it absorbs the axial wave once, but the reflections inside the horn are absorbed many times. (Since the reflected energy is reflected back down the throat, off the walls, off the mouth, etc...) Also, just to be a complete lunatic, I put a *full* roundover on the horn. In other words, the roundover extends *into* the mouth. Because the top of the horn is baffled, my hypothesis was that this wouldn't affect the low end dramatically. Besides, if half a pipe is better, how about a full pipe? Here's what the horn looks like for these measurements: Note the roundover on the sides *and* the mouth. The horn has been filled with 30ppi reticulated foam. The 2" PVC pipe extends all the way into the mouth now. In the previous measurements, it was a half pipe, duct taped to the bottom of the horn. In the side view you can see this is a REALLY small horn. That's a Radian compression driver. Of course, this is outside the car. The polar measurements were performed inside the car. And speaking of polar measurements, here they are. The untreated response is at the top. After the second stage of treatments, I measure the horn at the same voltage level. In the graph the second set of measurements were lowered by 10db. The HOMster with a horizontal roundover, a vertical roundover, and stuffed with reticulated foam What do you think? Here are my thoughts:
In summary, the objective measurements demonstrate that a small investement in PVC pipe and foam can reduce diffraction a great deal. And reducing diffraction improves the consistency of the on and off axis response. I am not able to measure HOMs, but I know what they sound like. In the next post, I'll describe the subjective improvement of these tweaks. Last edited by Patrick Bateman; 9th September 2009 at 06:13 PM. |
#13 |
After finishing my tweaks, I gave the HOMster a listen. Here are my thoughts.
My first reaction was anger - I was literally pissed off that this horn could sound this good. The HOMster went from an ugly duckling to a swan in an hour. I was *infuriated* I've been building horns for about a decade now, and I have a sizable collection of DIY designs. I've swapped out various compression drivers, dabbled in different curves, and obsessed for countless hours in front of Akabak and Hornresp. And a stupid piece of PVC pipe and a handful of foam made all the difference in the world. Seriously, I really wanted to set fire to all my other horns, the difference was THAT dramatic. While I have been building waveguides for a few years now, and using the foam religiously, I wasn't prepared for the improvement that they bestowed upon a lowly diffraction horn. If anyone reading this has a set of horns: Run, don't walk to your nearest Home Depot. PVC pipe is your friend. And get a foam plug if you really want to be blown away. It was particularly frustrating because I have a car depreciating in my driveway, and taking up a ton of space, which has tractrix horns driven by hard-to-find AlNiCo compression drivers. I invested months of work on those tractrix horns, and an hour of tweaks had trumped it. The only reason I still own the car is that it would take weeks to UNdo all the things I had to do to cram those giant AlNiCo compression drivers into the car. To give you an idea of their size, here's a pic. HOMster on the left, a horn I made in 2002 to the right, giant AlNiCo tractrix horns, and an elliptical OS waveguide. The three on the right are DIY. |
#14 |
High Order Modes are supposedly linear *decay* artifacts (..that are more apparent at higher spl's).
The freq. plots (while interesting), don't necessarily display artifacts produced by "HOM"s. What they *do* show however is the degree of imposed "ripple" created by the primary diffraction signature of the horn "mouth" to baffle". In other words the entire bandwidth is being modulated by the change from a high pressure region to a low pressure region. Now a Cumulative Spectral Decay plot (at varying levels), should display HOM's (if they exist).
perspective is everything |
#15 |
John
Nice thread. Pretty much confirms what I have been saying all along. Some people still won't accept it however. |
#16 | |
![]() I like the thread as well, but in precisely what way does it confirm what you have "been saying all along"? ![]() IMO it's more along the lines of what Jean-Michel has been saying all along: i.e. "TREAT THE MOUTH of the horn." After all, in this thread there is still a "nasty" diffraction slot present at the throat here.
#17 | |
"Higher Order Mode, its a term that I coined to define waves that propagate in a waveguide that do not go down the axis, but travel by bouncing off of the walls. " Having established that, note the following:
#18 |
Good thread. I'd like to see the 'towel mod' quantified with some measurements. For a towel, you could substitute thick felt, absorbing foam (as opposed to the semi-transparent reticulated foam), etc.
Dennis H |
#19 | |
My hypothesis is that that egg crate foam works on such a narrow band of frequencies that it's effect is barely noticeable. If I had the room it would be great to try this with a MONSTER roundover, like 4" or even six inches. With the horns the best tweaks seemed to be:
#20 |
Sure sounds familiar to me.
| I learned A lesson in Grounding today! | Zero Cool | Solid State | 2 | 29th December 2007 12:06 PM |
| what have learned....+ and - | timothy | Full Range | 3 | 9th October 2005 07:38 PM |
| Some learned advice needed. Pretty please. | G | Digital Source | 1 | 13th April 2005 05:33 AM |
| Learned a lesson today | Ralph | Tubes / Valves | 9 | 18th December 2003 06:35 PM |
| Page generated in 0.17856 seconds (84.56% PHP - 15.44% MySQL) with 11 queries |
