#121 |
Hello Mr. Bateman,
First off, I must Thank You for the very interesting and educational threads on HOM of horns! Through these threads I was introduced and intrigued by Dr. Geddes work--amazing stuff! One day I hope I will be fortunate enough to sample his system and have one in my home In the meantime, I would like to build my home theater system using USD A-700 horns from my previous car--car was broken into and all my components besides the horns were stolen. Currently I have a Marantz sr6005 receiver on route and the horns and nothing else. My knowledge in audio is elementary at best and I am pretty much stuck. I was wondering if you could recommend a budget setup for this type of system (I plan to go stereo rather than surround sound). Here are some specific questions that I had: 1)Should I use a passive or active crossover? 2)Should the crossover be at the manufacturer's recommendation of 800zHz? 3)Midrange frequency coverage: Do you recommend pairing with some midrange drivers (I can't seem to find any one way midrange bookshelf speakers straight out of the box) or do you think pairing with a sub (or three per Dr. Geddes) would suffice? I know your time is precious and so any help would be much appreciated! Thank you in advance, Fred |
#122 |
I've received a few emails asking about where to buy the reticulated foam that I used in this project. I bought it from McMaster Carr. They stock a gazillion products, so I thought I'd post the part numbers on this thread, in case you guys could use that.
I am using 1/2" reticulated foam. It's part #2195K53 and it's $107 for a lifetime supply. (OK, that's forty square feet, but it's more than I'll ever need.) I first used 1/4" foam, which is part #2195K52, but I wouldn't recommend that. It's a p.i.t.a. to work with due to requiring twice as many layers. Geddes has noted that ideally you should use a solid block of the stuff. Pretty sure that would cost hundreds of dollars though. If I'm not mistaken, plain ol' polyester fiberfill will function in a similar manner as the reticulated foam. The foam has a number of advantages though:
The advantage of polyfill is that you can get it at Wal Mart, any craft store, it's 1/10th the cost, etc |
#123 | |
| I learned A lesson in Grounding today! | Zero Cool | Solid State | 2 | 29th December 2007 11:06 AM |
| what have learned....+ and - | timothy | Full Range | 3 | 9th October 2005 06:38 PM |
| Some learned advice needed. Pretty please. | G | Digital Source | 1 | 13th April 2005 04:33 AM |
| Learned a lesson today | Ralph | Tubes / Valves | 9 | 18th December 2003 05:35 PM |
| Page generated in 0.32162 seconds (20.56% PHP - 79.44% MySQL) with 11 queries |
