#91 |
I would tend to agree with that. When the house is very dirty just picking up a few things makes it look a lot better. But a clean house is much harder to improve upon.
#92 |
Since I can't find a link to the PDF anymore, and its far too big to up the
whole thing again here. Here are paragraphs relevant to your horn shape. You might still want to track down the original article in its entirety. |
#93 |
Custom Title
I'm going to try some reticulated foam (guy just wanted rid of it at the pet shop, apparently the size was wrong. Score, $1.25 for each piece (about a 5.25" dia cylendar, 1.25" tall) and edge termination on some JBL 2370s.
Earl, would it be correct in assuming that much of the coloration of a diffraction slot itself could be attenuated by the foam? I'd think that reflections back towards the diaphragm would be a significant part of the issue. I'm planning to cut it as well as I can to match the throat profile and extend past the diffraction slit, am I likewise correct in assuming that it can be rather "rough" cut? Should it be fastened to the sidewalls? I'm also assuming that we'd see a far less significant effect from roundovers on the sidewalls, where the horn flare pretty smoothly transitions into a flat front baffle. I'm planning to use Aitwood Anderson International - StoreFront for the roundover transitions.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#94 |
I've seen those corner pieces. They look very attractive.
I am inclined to believe that the foam would help any horn and the worse that it is the more that it would help. You can probably rough cut it and just hold it in place with compression. |
#95 | |
I originally filled the horn with foam - from the phase plug of the driver to the mouth. I found that I could take out the front third, or so (as measured by depth), without reducing the apparent effect. That front third makes up the bulk of the foam (like the bottom of a pyramid). What I care about are specific reflections that create echos (HOM?). Sounds like, well, like a horn. I don't like the speakers to sound like someone is singing into a metal trash can (even though the effect was slight with the untreated waveguide). Don't like back loaded horns for that same reason. I never spent much time thinking about a generalized sense of harshness, so I don't know if that's something distinct from the perceived echos, or whether it's just different frequencies that affect our perception differently. I would guess that there is some higher frequency cut-off where an echo no longer sounds like an echo. I would think that it's related to frequency as well as the amount of delay, and probably the number of reflection cycles and rate of decay - and some relationship between all those (and probably more) factors. Pretty complicated, I'd guess. Sheldon |
#96 |
Tried something stOOpid that didn't work, but thought I'd share all the same.
NXT exciter near the throat of my StyroSmith. Does not appear to have any use or abuse as a unity driver in this application. Maybe its just septums of a Smith horn damp out the flex modes? Certainly got along plenty well enough with large flat panels of the same exact pink extruded polystyrene foam. Proabably comes as no surprise to those who know, that this shouldn't work. But I was dumb enough to try it anyway. Figured I'd save other dummies the five bucks price of admission to repeat the experiment. Last edited by kenpeter; 8th December 2009 at 01:13 AM. |
#97 | |
Rob
"I could be arguing in my spare time" |
#98 | |
Custom Title
#99 |
Glad to read some else thought of roundovers, I thought I was alone! I've been using 4" PVC white pipe cut in half length ways for my roundovers. Cut to fit the edge lengths of my mid range box (ATC soft dome) and it smooths out a roughness in the sound from diffraction. Also use it on my tweeter clear plastic baffle for similar good effect. I use clear 2" wide heavy duty packing tape to tape on the pipe. Looks like crap but sounds good, not great. In your horn you might also try using wool from an old sweater or jacket to line some part of your horn. Different foams, wool, felt, etc work at different frequencies. Wool felt is supposedly good for higher frequencies. Have fun! |
#100 | |
Custom Title
| I learned A lesson in Grounding today! | Zero Cool | Solid State | 2 | 29th December 2007 12:06 PM |
| what have learned....+ and - | timothy | Full Range | 3 | 9th October 2005 07:38 PM |
| Some learned advice needed. Pretty please. | G | Digital Source | 1 | 13th April 2005 05:33 AM |
| Learned a lesson today | Ralph | Tubes / Valves | 9 | 18th December 2003 06:35 PM |
| Page generated in 0.16056 seconds (82.23% PHP - 17.77% MySQL) with 11 queries |
