Old 9th September 2009, 07:18 AM   #1
garlach is offline garlach  Luxembourg
Default Re-jigging KEF Corellis into new system
I have inherited the drivers (no crossovers) from a pair of KEF Corellis (B200 SP1063 and T27 SP1032). I am fairly new to hi-fi audio, so I'd be glad of some help with a few questions:
1. I've gathered that these are quite high-quality, sought-after drivers. But just how good are they compared with modern-day equivalents?
2. I can best use them in the configuration of two 2-3 litre treble units incorporating the T27s, and a single bass unit, with one or both of the B200s. I can bi-amp the system with a 4th-order active crossover at 300Hz. Any suggestions for a midrange driver well-matched to the T27 for the 300-3.5kHz range? (probable crossover: series 1st-order at 3.5kHz). Most of what I can find (e.g. Monacor MSH-115) is "too efficient" i.e. I'd have to L-pad the midrange driver, not the tweeter… how serious a drawback is this?
3. For one (or two) B200s for the sub-300Hz range, what are my best options keeping cabinet size to a minimum? WinISD tells me a 56l vented box would give quite a good bass response, but I'm also considering a folded 1/8wave TL, which could be smaller I think.
Thanks to anyone with any ideas!
Old 9th September 2009, 07:52 AM   #2
Default re: re-jigging KEF Corellis
I should have made clear that the active crossover can optionally combine the <300Hz signals to a single channel, meaning that I can get away with a single bass box with one or both B200s installed. I tested an isobaric configuration in WinISD to get the 56 litre size.
Old 9th September 2009, 04:28 PM   #3
OK, not a popular topic! ..... could someone maybe help me out on Question 1 though?
Should I build around these old drivers because they're good (btw I'm now thinking <150Hz is better for a merged single bass channel) or should I just buy modern unit because they are better? Sorry for the ignorance and really basic question but ...
Old 9th September 2009, 04:35 PM   #4
frugal-phile(tm)
planet10's Avatar
Factory data on your B200
http://t-linespeakers.org/drivers/b200.html
These do not work well in a really small box. The usual role of the B200 was as a mid-bass all the way up to the T27 at 3.5kHz. With a 4th order XO you can probably get away with 3kHz.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Re-Jigging the jig: Speaker testing device for Arta, Speaker Workshop & HOLMImpulse MJL21193 Multi-Way 263 9th January 2012 11:24 AM
Help with PSU for Tri-Amp System snax Power Supplies 9 16th July 2007 08:17 PM
First HT system. 5.1 help truz05 Multi-Way 8 8th February 2007 06:09 PM
PIC Of My system in the car Dj BASS AMP Car Audio 10 10th January 2004 10:38 AM
Your First System nobody special Everything Else 14 13th December 2002 02:19 PM
Page generated in 0.29468 seconds (24.79% PHP - 75.21% MySQL) with 10 queries
