hello guys i just want any final thoughts on this before i click the buy button.
i plan on making a pair of bass reflex book shelf speakers. the internal distentions are 13.25"H x 8"W x 7.5"D and has a total volume of 13L but with the port and some crossover it will come out to around 12L. the port is 1 7/8" in diameter, flared, 4.3" long, and tuned to 55Hz. the box is going to be made of 3/4" MDF except the front baffle will be made up of some 3/4" hard wood. ima use a 2nd order L-R crossover at 3000Hz and have a L-Pad in the high pass and zobel in the low pass. One question with the zobel part of the network, my calculator says i need a cap of 26.6uF but i cant find any. i was told that you can put caps in parallel to equal the uF that i need, but i read that the lower uF cap will draw more volts and im concerned. did i chose a good combination? Parts list 2x Tweeter: DC28FS-8 2x Woofer: Peerless 830656 2x Port tube: Port Tube 1-7/8" ID 2x Binding Post: Round Speaker Terminal 2-7/8" Gold Binding Post 4x Inducer: Jantzen 0.85mH 18 AWG Air Core Inductor Caps: 4x Dayton PMPC-3.3 3.3uF 250V Precision Audio Capacitor , 2x Dayton PMPC-6.8 6.8uF 250V Precision Audio Capacitor , 2x Dayton PMPC-20 20uF 250V Precision Audio Capacitor 2x Resister: Dayton DNR-7.5 7.5 Ohm 10W Precision Audio Grade Resistor 2x L-Pad: L-Pad 100W Mono 3/8" Shaft 8 Ohm Last edited by bobfig; 5th September 2009 at 01:17 AM. |
#2 |
Hi
Placing the port between the midbass and tweeter is bad practice. You want the 2 drivers to simulate a point source and have better power (polar) response. Using crossover calculators is more of a miss than hit in general, but can be a start for some folks. If you search the net or even this site you can probably get a better crossover design for this. Otherwise you might need to account for loss of bass in your Xover design because of small cabinets and far field listening ie BSC. As far as answering your Q about zobels, I use NonPolar electrolytics in that application. Using expensive film caps are IMO wasteful for parallel connection esp using a big R in series. Just use any value in the range of 20-30 uF, it's not that key for accuracy and may even work better without one. I think the Zobel resistor s/b =Re+(5-10%
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust Last edited by infinia; 5th September 2009 at 08:44 PM. Reason: port location |
#3 | |||
hay thanks for a response.
#4 |
Non of the good designers use crossover calculators!
read this http://www.zaphaudio.com/ZBM4.html also crossing at 3KHz plus no zobel required! Look at the crossover network response. he talks about BSC due to changing the value of L in the lowpass section. Using slotted ports have a correction factor (they act like a longer tube ) tube ports right at the inside wall behave similarly
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust Last edited by infinia; 7th September 2009 at 05:07 AM. Reason: Port correction |
#5 |
Don't use hardwood! It's far more resonant than ply or mdf and has other bad habits to boot.
Birch ply with a good hardwood veneer will always sound better. Last edited by raypalmer; 7th September 2009 at 05:53 PM. |
#6 |
ok so no hard wood. its all going to be painted 3/4" MDF. would the bottem slot be better or should i do duel 1" flared ports down there?
#7 |
Seems if you move everything up and make the mid-bass edge touch the tweeter flange, the original tubular port should fit fine.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#8 | |
Another option would be to pinch the whole box so it's narrower and taller, only so much as to allow the port in. |
#9 |
Thanks guys for the ideas. Another question, would it be better if the port is centerd in the baffel or offset? And if you offset the port would the cabnents have a serton side they have to be on? i.e. the ports be on the inside or the out side of the woofers.
#10 |
| Page generated in 0.17511 seconds (60.52% PHP - 39.48% MySQL) with 11 queries |
