I have a specific application for a 8" bass driver to cover 80 to 400Hz and hopefully flat to 700Hz. It needs to reach 110dB and handle 150W RMS.
The trouble is it needs to fit in a 6L cabinet (well stuffed and lined with blackhole 5). I will have a 12" subwoofer underneath this and above this is a unity horn. Does anyone have any experiences/suggestions for such an application? I would prefer not to change the baffle cutour but have admittedly been looking at 6 1/2" bass/midbass drivers. I do have a DCX so I can work with a driver that is close to the fit. Thanks for your time |
#2 |
frugal-phile(tm)
The closest thing i can think of is CSS SDX7. Q=0.7 in 7 litres. With all the damping you have, Q should come in a bit below that in your box.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Hi Dave. Good suggestion! The xmax is great. Just wish it was a little more efficient. Have you found that it matches the T/S in the ones you have used?
#4 |
frugal-phile(tm)
Yes. Sealed isalso very forgiving.
dave
| Mid/Bass Driver QTS for Sealed Box Loudspeaker? | bssk | Multi-Way | 0 | 7th November 2006 06:57 AM |
| Making a bass cabinet, driver selection. | ruerose | Instruments and Amps | 21 | 29th October 2006 02:48 AM |
| AUDAX speaker, with "special" sealed cabinet | arcturus | Multi-Way | 1 | 27th September 2005 07:56 PM |
| Peerless CSX 10" Sealed bass modules | LageB | Multi-Way | 13 | 23rd November 2003 04:45 AM |
| Bass(ish) driver for 1.5cf sealed box. | sfdoddsy | Multi-Way | 7 | 8th September 2002 07:32 PM |
| Page generated in 0.30749 seconds (19.19% PHP - 80.81% MySQL) with 10 queries |
