I'm working on my first diy speaker pair. I think I'm almost ready to start putting everything together. I'm trying to determine the values for my zobel network for 2 parallel drivers. I've seen xo schematics with 1 zobel network for a pair of parallel so I'm guessing it can be done but not sure if it's ideal. Is it proper to have a zobel network for each woofer or is it okay to use 1 for both?
If 1 network is acceptable, I know that the Re of 2 identical speakers in parallel is half, but does that also stand for the Le of the 2 drivers? Also, I'm assuming (which I know what that probably makes me) that I would use half of Re for determining zobel component values. Is that correct? I hope I'm explaining my question properly. Let me know if you need more info. Thanks so much. |
#2 |
If 1 network is acceptable, I know that the Re of 2 identical speakers in parallel is half, but does that also stand for the Le of the 2 drivers? Also, I'm assuming (which I know what that probably makes me) that I would use half of Re for determining zobel component values. Is that correct? Thanks so much.[/QUOTE] hello. perhaps this thread can help you................ http://www.diyaudio.com/forums/showt...25#post1873625 greetings......... |
#3 |
Thanks! I did search before I posted my question but I was searching for zobel network and for some reason didn't think to search post names for impedance e.q.
Thanks again! |
| dimentions of speaker box in speaker spec sheet? | Dan2 | Car Audio | 2 | 6th February 2009 05:34 AM |
| FS: Niles HDS-6L speaker selector w/ speaker protection. | Spasticteapot | Swap Meet | 0 | 27th May 2006 11:14 PM |
| SI Super-T and speaker AB switch to ONE speaker | Taperwood | Class D | 25 | 24th March 2006 02:08 AM |
| Some Speaker Completed Speaker Projects | dc270 | Multi-Way | 1 | 19th February 2006 01:33 AM |
| New Ribbon Speaker Technology - Approach the perfect speaker? | cocolino | Planars & Exotics | 49 | 16th January 2005 10:12 PM |
| Page generated in 0.07589 seconds (65.67% PHP - 34.33% MySQL) with 10 queries |
