Old 2nd September 2009, 10:26 PM   #1
Default Which bass/mid for this application?
Hi everyone, I am looking for the ultimate bassmid to use in a MTM configuration with a Raven R3 (or possibly MMTMM).
The driver should be 8 ohm, 6-7" and any enclosure type is fine (reflex, sealed or TM). The crossover points will probably be 80 Hz and 1-2 kHz (3rd or 4th order)
Which drivers should I look at? I've been out of the DIY game for 10 years and I'm sure a few things have changed since then.
The Scan Speak 18WU/8741T00 looks quite interesting but I can't find any user feedback. And what ever happened to their carbon fibre/paper domes? I once used those and liked them.
Old 4th September 2009, 10:48 PM   #2
anyone?
Old 4th September 2009, 11:44 PM   #3
Hi!
http://www.zaphaudio.com/6.5test/
http://www.audioheuristics.org/measu...asurements.htm
crazyhub
Old 5th September 2009, 11:33 AM   #4
Those links look very interesting. Thanks for posting. They should keep me busy for a while
Looking for tube for application dsavitsk Tubes / Valves 11 21st November 2006 02:37 AM
Old RCA application notes....where? jez Solid State 9 19th October 2006 11:04 AM
Fairchild amp application blink Solid State 12 15th December 2005 10:45 AM
EBS: Powerport application masterp2 Multi-Way 132 25th February 2004 07:26 PM
AGC for PA / SR application AudioFreak Solid State 4 13th February 2004 09:13 PM
Page generated in 0.08282 seconds (65.38% PHP - 34.62% MySQL) with 10 queries
