Old 1st September 2009, 02:44 PM   #1
room237 is offline room237  United Kingdom
Default Behringer B215 Replacement speaker
Hi i am not sure if this has been posted in the correct section? I am looking for a replacement 600watt 8 Ohm 15" speaker as a replacement for one which has blown. I have tested the speaker or i should say woofer and it is giving no reading at all meaning that the coil is probably gone. I have also tested it outside the cab and the cone does not feel nice when moved top to bottom.
Can anyone suggest where i could get a replacement speaker in the UK. And what good brands would you recommend to replace the Behringer sopeaker.
I really do not wish to go to Behringer as they will probably give a price which would mean it would be cheaper to go out and get another cabinet.
Thankyou in advance.
WANTED !!! Behringer DCX-2496 Ultra replacement... speakrsrfun Swap Meet 4 6th May 2009 07:32 PM
Revox B215 for parts. cinematographer Parts 4 5th January 2009 03:52 PM
FS: Behringer and DIY speaker tf1216 Swap Meet 18 27th August 2008 04:49 PM
Behringer Replacement faders ? Enzo?? Zero Cool Instruments and Amps 0 8th April 2007 09:56 PM
Page generated in 0.07572 seconds (61.78% PHP - 38.22% MySQL) with 10 queries
