Old 16th August 2009, 01:07 AM   #1
tomat is offline tomat  Indonesia
Default accuton C23 cut frequency?
Please help,how much the ideal cut frequency for accuton C23 tweeter. Thanks
Old 16th August 2009, 02:04 AM   #2
sorry, C12 i mean,25mm ceramic tweeter. thanks for help
Old 16th August 2009, 12:22 PM   #3
Inductor's Avatar
Default ACCUTON C²12-6
TOMAT,
What is your project?
This tweeter is very good for a first order xover.
It looks good to follow the sugestion. And it looks good for experimentation also, like a low xover point too, like 1K6 and up as a general rule (maybe not in a 1.order).
High efficiency, ferrofluid filled tweeter with 25 mm light weight concave ceramic dome. Perfect choice for 3-way systems or small, low-output 2-way designs. Very high resolution and very good dispersion up to 42 kHz. Low resonance frequency allows first order filtering and a crossover frequency as low as 2 kHz.
http://www.accuton.com/e/data/produc...2/e_C12-6.html
Old 16th August 2009, 02:46 PM   #4
Default Re: ACCUTON C²12-6
Originally posted by Inductor . Thanks,I build two way bookshelf,the woofer is accuton C95 double voice coil,I'm trying to cut the tweeter around 4khz,with 2nd order,but I feel the tweeter still too bright
TOMAT,
Old 17th August 2009, 12:17 AM   #5
Inductor's Avatar
Do you mean:
(1) ACCUTON C²95-T6
http://www.accuton.de/e/data/product.../e_C95-T6.html
or;
(2) ACCUTON C²92-2x6
http://www.accuton.de/e/data/product...e_C92-2x6.html
Do you have a closed enclosure? What size is your box?
Old 17th August 2009, 03:57 AM   #6
foo is offline foo  Tibet
I think high XO point with 1 order is a good idea.
Low XO is a bit too difficult for this driver.
C44 is used for low XO application more.
Old 17th August 2009, 04:53 AM   #7
Do you mean:
(1) ACCUTON C²95-T6
or;
thanks,the exact is no 2,c92-2x6ohm,the enclosure is vented with internal volume 21L,as i calculate with win isd,now i'm try to invert tweeter polarity,still with 2nd order xo,the freq around 4 - 4.3khz,it's better,but still make my ear fatique
here is pic of my speaker
Old 17th August 2009, 09:17 AM   #8
Thank you Foo,I will try that,probably around 6 or 7khz with 1st order
Old 17th August 2009, 09:37 AM   #9
Inductor's Avatar
Default 2-WAY Accuton WO/C²92-2x6 & TW/C²12-6 2-order
You can test/use this xover.
You can ajust the L-Pad for your convenience.
For the tweeter resistor R1=3,5ohm, if you think you have to much wizz (@>10KHz) use a higher resistor (ex: R1=4,5ohm).
To adjust tweeter attenuation (shelving) use resistor R2. If you use a lower resistor than 7R you are going to have more attenuation (~1dB for a 6R0), or the opposite to make it more alive.
It's a (+/-) 2.2KHz, 83/84dB, 2.order xover.
(Note: this xover is for the 2 woofer coils in series)
Old 17th August 2009, 11:50 AM   #10
Inductor's Avatar
Default 2-WAY Accuton WO & TW 2-order - NEW
Considering a few factors (this is a simulation) here is a new xover based on the same idea (now 86dB, xover at 2KHz). Now the key here (testing and patience), besides the adjusting of the L-Pad (new) like I said, is the 8,2uF cap. Let's say you need more power on the xover band at ~2K0Hz, then change it with a 10uF cap and output will go up about 1 or 2dB, only for the tweeter at 1,5K/4KHz band. Testing is essential. Report.
(Note: People that want to use clones can use VISATONS. Woofer AL 170 8 OHM and Ceramic Tweeter KE 25 SC 8 OHM. They will work fine with this setup. Make sure to give 2dB more attenuation on the tweeter. Make R1=~5,2ohm and R2=~7,6/8,2ohm. This setup is for 84dB)
Page generated in 0.20313 seconds (46.32% PHP - 53.68% MySQL) with 10 queries
