Old 29th August 2009, 02:30 PM   #1
jlsem is offline jlsem  United States
jlsem's Avatar
Default Large Onken for Tru-Sonic
I would like to build an Onken enclosure for my Tru-Sonic 206 AXA drivers. The problem is the only parameter I have for them is a free-air resonance of 35Hz. I have downloaded the Onken calculator but have no idea how to make it work. At some point in the future I would like to use the enclosure for a Supravox 400-2000 which has an Fs of 23Hz. Can someone please help?
TIA,
John
Old 29th August 2009, 05:10 PM   #2
GM is offline GM  United States
GM's Avatar
As a general rule, a cab designed for a 23 Hz Fs driver won't work well with a one designed for a 35 Hz Fs driver and vice versa unless their Vas, Qts T/S specs are considerably different.
Regardless, with no specs, the best I can recommend for the Stephens is to use one of the Jensen Ultraflex designs the Onken calculator is derived from and tweak the tuning to suit using either a tube amp with variable DF bass control or dial it in with a cheap pot, then measure its resistance and replace it with a non-inductive power resistor grid and have plenty of power on tap to compensate for system's reduced efficiency.
The Supravox's specs if ~accurate look like they can be used in the Jensen cabs with the same tuning caveats, though plugging them into the calculator would in theory be a better match.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Onken, anyone? cyclotronguy Multi-Way 155 28th May 2009 05:22 AM
FS: Large inductors, Large Ports, and Leaky Holes luvdunhill Swap Meet 10 6th March 2009 03:01 PM
Onken cabinet The gun Multi-Way 9 11th November 2008 05:35 PM
6c45pi : sonic utopia or sonic hell? Kashmire Tubes / Valves 29 5th March 2004 06:04 PM
Jensen Onken f.bcn Multi-Way 1 13th November 2002 07:09 PM
Page generated in 0.53035 seconds (10.93% PHP - 89.07% MySQL) with 10 queries
