Old 11th May 2003, 06:53 PM   #1
chops is offline chops  United States
chops's Avatar
Default I'm trying to find these drivers?? Does anyone know??
As I usually have more than one project going on at one time, I am looking into another experimental project, "The Voigt Pipe".
For those of you who know the point behind these, they are best utilized with a single fullrange driver. The ones I am looking for is the Fostex FE166e fullrange drivers. These seem to be the next best thing to the Lowthers at a fraction of the cost, and since this is experimental, I don't want to put a lot of cash into it.
So here's my question to all of you....
What other places are there that sell this driver for less than Madasound? They are selling it for $61.05 each which is not that bad. I will spend that much if I have to, however, if I can find them a little cheaper, that would be nice.
Actually, if anyone here has a pair new, used, and or similar, I might be interested. I want at least a 6.5" driver to get some decent bass extension.
Let's see what we can come up with!!
Charles
Old 11th May 2003, 08:29 PM   #2
Banned
Question: are Fostex fullrange drivers the best thing to Lowthers or are FE166e ?
I ask because i would like to try a simple fullrange open baffle speaker with a fostex and think about which one would be best. Isn't 200 mm better here than 160? (In case there is no additional speaker for low frequency reproduction)
edit: size should be 153*153 cm
Old 11th May 2003, 08:36 PM   #3
fanta is offline fanta  Poland
Hi
You dont find them cheaper.
Maybe used on ebay?
Old 11th May 2003, 08:46 PM   #4
chops's Avatar
True, a 200mm driver is better for bass extension, however, I would only be using these for orchestra music and jazz, and maybe some light organ music. Ah heck, actually, I would probably play everything through them, but the 160mm drivers are less expensive and that is my main goal as of right now.
Besides, with the smaller, lighter driver, the top end will probably be a little more extended. And this system is going to be strictly 2-channel using an old, (1978), Technics SU-8099 integrated amp rated at 100 watts per channel from 5Hz-100KHz and a Teac 5 disk changer that I have sitting around. Eventhough it is overkill for the Fostex drivers, this amp has always had an excellent, transparent sound with the ability to completely bypass the tone controls.
Charles
Old 11th May 2003, 08:53 PM   #5
planet10's Avatar
Fostexs are a much less expensive (in most cases) alternate to Lowthers. Fostex is the "high-end" arm of Foster and produce some darling's. As with any driver implentation plays a key role, and some of the Fostex with the right marriage sound real fine. Lowthers seem much more tempermental -- it will be interesting to see the results of Martin King's DX2/3/4 experiment, which was proceeded by Fostex 164 and 208 Sigma designs.
It is a trade-off between lows & highs -- the 8" Fostex are very often used with helper tweeter, the 4" units need helper bass, the 6" units seem to be the best compromise if you aren't adding any help.
BTW you will probably find Madisound pricing to be about the best around.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th May 2003, 08:54 PM   #6
planet10's Avatar
With that source you might well want a slightly soft top end.
dave
Old 11th May 2003, 09:04 PM   #7
chops's Avatar
dave
That's what I thought as well and is the reason for using that Technics amp. Also, I will be using some homemade 0.5m interconnects. Not sure about speaker cables yet though.
Charles
Old 11th May 2003, 10:13 PM   #8
chops's Avatar
I've been looking on the internet for over an hour now for Fostex retailers other than Madasound. Are there any others out there that sell them or is Madasound the only one?
Charles
Old 11th May 2003, 10:16 PM   #9
http://www.fostexspeakers.com/fostex.html
Old 11th May 2003, 11:26 PM   #10
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Solen in Canada carries their line. Not sure of anywhere else though.
Where can I find reviews of Fostex FE166* drivers? Forsman Full Range 5 9th May 2009 10:50 PM
'Fast' bass drivers and how to find them ashok Multi-Way 150 26th April 2004 02:47 AM
Can't find good 15 inchs drivers JBL Multi-Way 14 16th October 2002 11:22 AM
Page generated in 0.10844 seconds (89.71% PHP - 10.29% MySQL) with 10 queries
