#11 |
Thanks Ron E. The excursion issue is much clearer to me know. But I'll stick to the latter project due to several uncertainties.
It seems to me that a project using high end components is a bit overkill for a first timer. |
#12 |
How precise must the netto volume vs. tuning freq. be? I've ended up having approx. 0,4L (14%) more netto volume than planned.
I've read a couple of articles about crossover networks, but for this first time project I would prefer to use a properly tested design. Can I use this design? ![]() If yes, what should the value of the resistor in series with the tweeter be? The Vifa midwoofer has a sensivity of 85db, the tweeter 90db. |
#13 |
this is andy G's territory. but i guess you'd need more than 4 ohms to level the HF.
remember the XO sees the resistor so yo have to change teh values of teh L to keep the same XO freq.
...still looking for the holy grail. |
#14 |
Hmm... thanks. But to what value? And what is the XO freq. of this circuit?
#15 |
andy G where art thou?
#16 |
Speaker builders,
I have currently used the LC cross over to upgrade a commercial DynAudio MK2 speaker. The drivers used in this cabinet were the 17W75 woofer and the D-28AF tweeter. The speaker gained al lot with this new cross over, the overall sound is more open and airy. I changed the series resistor for the AF tweeters to 3.3 Ohm without noticing any difference in the sound of the speaker. I have exprimented with several values from 2.2 tot 3.9 Ohm. With 2.2 Ohms the tweeter was to bright. I would recommend to experiment with the LC cross over you will find the proper value for R1. Regards Piersma |
#17 |
Please forgive me.... I can't stop asking questions.
What should the value of the other resistor be, then? |
#18 |
I left it 2.2 Ohms this resistor its value not extremely sensitive.
#19 |
diyAudio Chief Moderator
I have posted a thread today about a speaker using a Morel and an Audax 8 inch. I took long to tune and it is proven. I think it suits your caution for building a not so expensive two way.
You may give it a shot. If a couple of Morel tweeters are lying around... |
#20 |
the resistor in the center has little acoustic consequence it is to prevent the impedance to dip too low in the range of freqs. handled by both drivers.
| Comment on my DIY Sub Design | htgeek | Subwoofers | 22 | 8th April 2005 05:26 AM |
| Please comment this design | promise | Solid State | 0 | 20th January 2005 05:25 AM |
| comment on my cabinet design..... | AudioGeek | Multi-Way | 1 | 3rd May 2004 06:18 PM |
| Pls Comment on My MTMWW Design | kestrel200 | Multi-Way | 24 | 2nd April 2004 02:30 AM |
| comment on this design, please. | JAZZ2250 | Tubes / Valves | 6 | 24th November 2002 10:45 PM |
| Page generated in 0.16734 seconds (51.42% PHP - 48.58% MySQL) with 10 queries |
