I'm running the HDS Tweeter in my speakers and I'm running into some lobing/integration problems from the MTM woofers being spaced fairly far apart. I built the Elsinores, but I'm running into problems because I listen fairly near-field, and the speakers sound better the lower I drop the crossover point. I'm set the crossover point at 1.5khz currently, with an active crossover slope of Linkwitz-Riley 24db/octave. Is this as low as I can go, or can I go lower? I'm mainly worried about keeping the tweeter safe and not damaging it. |
#2 |
From that point of view I don't see a problem (Fs=700Hz). Now check that the output goes up ~4dB from 1K5 to 2K5Hz.
#3 |
With an electrical 4th order filter, the Peerless HDS can likely be crossed lower than 1.5kHz without issue, however be sure to consider the driver's natural rolloff.
The power of Science compels you! |
#4 |
If you have room even a smallish waveguide could help.
#5 | |
http://en.wikipedia.org/wiki/File:Li...utterworth.png http://www.integracoustics.com/MUG/M...cles/circuits/ Last edited by Inductor; 27th August 2009 at 09:19 AM. |
| Lowest Xover point for SEAS 27TDFC | xmutan | Multi-Way | 15 | 29th December 2006 09:01 PM |
| Looking for Tweeter w/ Low XO Point.. Tang Band? | kfr01 | Multi-Way | 15 | 8th December 2004 03:56 AM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| Point to point crossover soldering | Ilianh | Multi-Way | 9 | 24th December 2002 04:14 AM |
| Sub crossover point | AudioFreak | Multi-Way | 2 | 31st December 2001 11:33 AM |
| Page generated in 0.23978 seconds (30.93% PHP - 69.07% MySQL) with 10 queries |
