Hello,
Seems that Chinese replicate the RCA 1428: http://www.lmaudio.net/html/lmaudio.html# A Google antomatic translation gives: "China's first excitation Alto Drive - 1428 - The RCA-1428 as a blueprint for a perfect reproducibility - 1937 RCA to RCA-1428 produced the perfect "blueprint" to reproduce - Using pure iron magnetic circuit, magnetic field excitation. - Use the large 5.5-inch phenolic diaphragm, - The unique design of turbine-type phase plug - Equipped with 1.5-inch and 2 inch hose then (with ALTEC / JBL horn with such access) Technical Data - Frequency Response: Bandwidth 400HZ-12kHz, (then 22A horn test 150HZ-10kHZ) Sensitivity: 100dB, Impedance: 16Ω, Excitation: 300V / 60mA " Best regards from Paris, France Jean-Michel Le Cléac'h |
#2 |
Okay, 120 views so far and no replys. I guess I'll be the first to bite on this.
It looks like a nice reproduction piece. I like the use of the phenolic diaphragm over that carbon fiber one that Cogent uses. The big question is what kind of cost is it, and how do you purchase them? Rgs, JLH Cogent carbon fiber cone below.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way! Last edited by JLH; 27th August 2009 at 02:18 AM. Reason: added picture |
#3 |
Jean-Michel, John,
Hi guys! Yes, I'm still alive. Same Questions. And a few more; Do they use an all phenolic cone diaphragm, or have they 'copied' Cogents? Paul B
Paul Butterfield |
#4 |
LIST PRICE (about 20% off at dealers):
HT-70 (WE 597) is RMB 26000/pair (includes supply) 555 is RMB 13000/pair 1428 is RMB 22000/pair BA-15 is RMB 20000/pair 22A Horn is RMB 26000/pair You can try calling their Canadian distributor for English info... LOYALTY SOUND LTD. ALBERT YEUNG (403)-2448838 1107-8TH STREET S.W.CALGARY,ALBERTA T2R 1L4 |
#5 |
Well, those are pretty but, yikes! $3200 minus 20% is still ~$2500 / pair. Someone would really be taking one for the team to buy one of these (somewhat an unknown quantity) and check them out.
#6 |
The LineMangetic Audio Design Lab product line were made known to a larger public a year ago through Srajan Ebaen, when he visited the Guangshou Audio Show. Out of curiosity, i contacted the company twice to know prices , but no response. Also their Canada importer and distributor didn't answer any email.
their field coil bass compression driver is unique indeed : some more pictures and links at my forum : http://www.audiovoice-acoustics.com/...read.php?t=585 l Last edited by angeloitacare; 27th August 2009 at 12:38 PM. |
#7 | |
#8 |
If i win the lottery i want those tube amps at the top of the page don't know if theyre any good but they look fantastic!
There are 10 types of people in the world: Those who understand binary, and those who don't... |
#9 |
If looks is all you care about, just build yourself some metal cabinets with some glowing tubes and have some Class D amps on the inside so at least they sound great. Lots cheaper than buying that stuff I assure you.
#10 |
Has anyone tried their speakers like RCA and WE ,how do these sound and the price mentioned by Loyalty is after discount or before discount
| Has anyone DIY a Field coil? | OzMikeH | Full Range | 18 | 16th November 2010 01:56 PM |
| The field coil revisited... | Rocky | Full Range | 2 | 16th May 2006 02:56 PM |
| Looking for jensen field coil | Kris9999 | Multi-Way | 2 | 10th February 2006 04:31 PM |
| What's a Field Coil Amplifier? | krzanik | Tubes / Valves | 9 | 14th May 2005 03:22 PM |
| Field coil wiring question | Art Heritis | Multi-Way | 3 | 29th October 2004 07:02 AM |
| Page generated in 0.15321 seconds (62.12% PHP - 37.88% MySQL) with 10 queries |
