Old 24th August 2009, 10:57 AM   #1
Default High efficiency 12 inch midrange - recommendations?
I am about to buy a 12" midrange driver to play the 150 to 800 hz band and it will hand over upper midrange to a Coral M100 unit mounted on a 400 hz tractrix horn. I'm looking for 100 db plus at no more than -3 db at 150 hz in a reasonably sized baffle.
My favorite at the moment is the 18Sound 12NMB420, but are there any good 12 inchers with even more sensitivity?
Cheers
Kris
Old 24th August 2009, 12:30 PM   #2
col is offline col  Australia
col's Avatar
How about the good ole JBL E120? Can still pick them up on Ebay.
col.
http://www.minirig.org.au
Old 24th August 2009, 02:07 PM   #3
jerome69's Avatar
Also
Beyma 12MI100 : http://profesional.beyma.com/pdf/12MI100E.pdf
Hava fun
Old 24th August 2009, 02:18 PM   #4
StigErik's Avatar
Or Beyma 12P80Nd....
101dB 2.83v @ 1m @ 2pi
http://profesional.beyma.com/ingles/pdf/12P80Nd.pdf
Old 24th August 2009, 07:20 PM   #5
The JBL might be interesting - sort of depends on what breakup there is close to x-over frequency and what it is capable of near the 150 cycles area.
The Beymas look mediocre and their sensitivity is closer to 95 db than what they claim.
The 18Sound driver is still top of my list...
Old 24th August 2009, 07:33 PM   #6
StigErik's Avatar
That 18sound driver looks pretty much like 95 dB @ 150 Hz as well.
It is interesting to calculate the efficiency using the T/S parameters, as this will say a lot about what you will get in real life around 150 Hz, where the speaker is more or less operating in free-field acoustic conditions.
The drivers mentioned have the following sensitivity based on T/S (into 4pi)
18Sound 12NBM420 93,0 dB
Beyma 12MI100 93,2 dB
Beyma 12P80Nd 93,5 dB
Old 24th August 2009, 07:38 PM   #7
Eminence Wizard looks smooth over that range. Course if you cross much above 800
you gonna start hearing the MI cone doing its thing... Claim 103dB, but the graph is
101 over the range of interest to you.
Old 24th August 2009, 07:55 PM   #8
Brett's Avatar
AE TD12M, 18Sound 12NDA520
http://sites.google.com/site/driverv...band-75-1558se
Old 24th August 2009, 08:58 PM   #9
ScottG is offline ScottG  United States
http://www.supravox.fr/anglais/haut_...rs/285_GMF.htm
http://oem.ciare.com/it/297/359/prodotti.php
perspective is everything
Old 25th August 2009, 10:21 AM   #10
Default wide baffle
The driver will be placed in a wide U shaped baffle with very large roundovers and very gradual transfer into 4pi. The 18Sound 12NBM420 is measured in a small enclosure. I expect baffle step to appear below x-over freq. in the set up that I use.
Kris
Hi efficiency 8 inch midrange - recommendations? Defo Multi-Way 91 28th November 2011 04:30 PM
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 04:46 AM
high efficiency midrange tsmith1315 Car Audio 15 16th March 2009 12:02 AM
Using 12" guitar element as high efficiency midrange? Elias Multi-Way 44 13th February 2009 01:21 AM
Looking for a high efficiency tweeter ... recommendations paulspencer Multi-Way 0 13th May 2004 12:04 PM
Page generated in 0.11738 seconds (78.36% PHP - 21.64% MySQL) with 10 queries
