calculating Q for spl due to RLC notch filter
Old 21st August 2009, 12:30 AM   #1
Dave R is offline Dave R  United States
Dave R's Avatar
Default calculating Q for spl due to RLC notch filter
Is there such a thing as a "Q" for the notch in spl caused by a parallel RLC filter, and if so is it calculated similar to the Q for the notch in the impedance? I can't seem to find this defined anywhere.
Numbers below are for example only.
freq atten
(Hz) (dB)
6184 -2.00
7039 -2.83
9016 -4.00 << (notch center freq)
11548 -2.83
13145 -2.00
Is it simply calculated at the point where the attenuation is .707 x SPL@ notch?
In this case where atten = 4.00 x .707 = 2.83, I'd be inclined to calculate Qspl as follows:
Qspl = [9016/(11548-7039)] = 2.0
What I'm leading toward is trying to size up the RLC values for a notch filter, when the Q for spl can be obtained from measured data.
Dave R
the 200% Norske
- Dave R
the 200% Norske
Old 21st August 2009, 12:58 AM   #2
infinia is online now infinia  United States
infinia's Avatar
Q is defined for any second order system response ie any RLC. So you would measure it the same way for a speaker driver or a sallen key filter stage. Q = central freq /half power BW
Hint use 3 dB away from central point not 0.707
If meas. using voltage then 0.707 is correct.
Vp=1 V then 20log*1/0.707= 3 dB
Old 21st August 2009, 04:59 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
See attached. Have fun.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 22nd August 2009, 01:56 PM   #4
Dave R's Avatar
Thanks Ron. Nice little spreadsheet.
- Dave R
the 200% Norske
calculating Q for spl due to RLC notch filterHide this!Advertise here!
Notch filter godless Multi-Way 5 22nd April 2008 09:26 AM
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Can Zaphs notch filter be used without the BSC filter? GuyPanico Full Range 0 21st July 2007 01:27 AM
Notch filter qguy Multi-Way 3 26th October 2006 09:26 PM
Does anyone have a notch filter for NSB's? GuyPanico Multi-Way 6 21st July 2006 02:06 AM
