sonus faber cremona
http://www.soundscapehifi.com/images...-005-4_LRG.jpg http://www.soundscapehifi.com/images...-005-5_LRG.jpg http://www.soundscapehifi.com/images...-005-6_LRG.jpg Using the pictures and specifications from the website, I "think" the drivers are: Scan Speak R2904 http://www.scan-speak.dk/datasheet/r2904_700009.htm Scan Speak 15M http://www.scan-speak.dk/datasheet/15m_4831g00.htm Scan Speak 18W http://www.scan-speak.dk/datasheet/18w_8531g00.htm I know the tweeter uses a different phase plug and the all drivers have some minor custom modifications, but really the stock drivers would be pretty close. Using the same cabinet dimensions 1120 x 350 x 565 mm (HxWxD). For the crossover the DEQX PDC-2.6 HD processor / active crossover http://www.deqx.com/products3.php What you guys think? Can it be done? Would land up with a pretty accurate cremona clone yeah? Last edited by soundengine355; 20th August 2009 at 11:41 AM. |
#2 |
the tweeter is a vifa xt25, as far as I know
Pictures from someone who did it: http://audioclone.free.fr/cremona/ |
#3 |
Parts Express has an XT25 buyout tweeter that may interest you:
http://www.parts-express.com/pe/show...number=279-180 ![]() Wrong phase plug, but right mounting plate. |
#4 |
You would be better of with a Marchand XM-44,
http://www.marchandelec.com/xm44.html Incredible performance, I used them with $11K Shahinian Hawks, so don't think this isn't a good product. Those DEOX processors are very expensive, you would also be better of buying a used pair of Cremona's off of Audiogon. I'm also a hobbyist, and have been building high-end for 17 years, and have used Marchand crossovers for many projects.
Airline Pilot-If it's not Boeing I'm not going. "Brain as big as a planet..." {sic} Nelson Pass |
#5 | |
#6 |
You need to start with some good simulation software. What you are trying to do will take some real work.
You need to start reading books from the library on the speaker building. Then you needs some good software (Lspcad, Leap, ect), or you can pay someone to design the crossover, but that will not get you the results you need unless you hired a professional. Some of the driver retailers do crossover design, but the cremona has a very, very well designed filter network in it. Take a look at a pro-hobbyist like Troels: http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm Read everything you can here, and then go to the library, there are some great books. Regards, Greg
| Sonus Faber Cremona Clone | audioPT | Multi-Way | 31 | 27th May 2010 04:26 PM |
| Help me with SONUS FABER AMATI clone | skatavic | Multi-Way | 3 | 8th July 2008 02:57 PM |
| Sonus faber cremona | jouch | Multi-Way | 10 | 22nd September 2006 06:57 AM |
| sonus faber cremona xt25 speculation | george a | Multi-Way | 12 | 21st April 2005 02:04 AM |
| Page generated in 0.16423 seconds (50.74% PHP - 49.26% MySQL) with 10 queries |
