Can someone explain the difference between the resistor placement for "calibration" in Dan's Soundeasy jig
http://www.diyaudio.com/forums/attac...amp=1174392176 and Zaph's http://zaphaudio.com/setup-se-calibrate.jpg Dan's jig completely shorts the 10 Ohm resistor. Is this not a problem because of the driver DC resistance?
"Beer makes you feel the way you ought to feel without beer." - Henry Lawson |
#2 |
There really isn't any difference from the point of view of calibrating the sound card. All that matters is that the amp does not see a zero ohm load. This is not a problem in Dan's set up due to the load of the driver, as you point out.
The key is that the probes must be connected to a point where they will see the same voltage. This is accomplished in Zaph case (Figure from my Design Guide) by moving the In probe to the same position as the Ref probe. In Dan's jig he accomplishes the same thing by shorting the ref resistance. I don't show a jig in my Guide because I personally feel it is unnecessary and just adds complication. A couple of test leads and a resistor wok just fine.
John k.... Music and Design NaO Dipole Loudspeakers. |
#3 | ||
| I just built Zaph's HiVi B3s speakers... thanks a lot, Zaph! :) | fjhuerta | Multi-Way | 21 | 23rd May 2011 10:46 PM |
| Speaker idea based on Zaph ZD5, thoughts please, Zaph? | wigginjs | Multi-Way | 23 | 3rd April 2009 05:09 AM |
| 10x probe question | NEO Dan | Parts | 5 | 22nd October 2008 03:40 AM |
| diy differential probe? | zilog | Class D | 7 | 18th April 2006 09:42 PM |
| Page generated in 0.24247 seconds (26.84% PHP - 73.16% MySQL) with 10 queries |
