Old 9th August 2009, 09:28 PM   #1
h@kan is offline h@kan  Sweden
h@kan's Avatar
Default Transmissionline Ipod Docking Station
I have a pair of Peerless P830986 fullrange drivers that I have never found a proper home for and when the need for a portable Ipod Docking Station came up I decided to try them out. The speakers will be driven by a tripath TA2024 amp board with some mods from the sureelectronics Tripath boards thread in class-d section.
Since I will place it on a desktop the size was limited to width 450mm, hight 200mm and depth 300mm. I found that any bigger than that would look a bit strange on a desktop.
With my new updated mathcad woorksheets from Martin J king (thanks for making the service avaiable again) I came up with a 62 inch 2:1 transmissionline with the driver position 8 inch from the closed end. Working with google sketchUp simoustanely gave me a quite funny construction that I really wanted to try out. The size, 450x180x275[mm], was actually smaller than my predetermined limits.
Mathcad MJK simulation
Sketch
Then I built the box out of 10mm MDF, the sides was sliced halfway to allow them to bend.
The baffle is just for testing purpose, I will build a new one from some fancy wood later.
I have not yet decided the finish but I think it will be white except from wodden baffle.
After a day of listening to it (passive driven by a gainclone) I decided to go all way with it and mount the amp inside it and try to find a proper ipod dock for it.
The bass response is really impressive remembering that there is just 3" drivers playing.
I noticed some lack of the higher frequencies and I think I will add some small tweeters crossed over with just a capacitor from 10000hz or so.
Did some diy measurements.
I will probably stuff the line a bit harder trying to get rid of some of the ripple at 100-200 hz.
Thats where I am right now.
Does anyone know where to find a panel mounted ipod dock?
Regards H@kan
Old 10th August 2009, 10:28 AM   #2
GDJ is offline GDJ  Canada
GDJ's Avatar
I like what I see so far. Nice work!
As for the iPod dock, I have no idea.
Old 10th August 2009, 10:50 AM   #3
chris661's Avatar
You can buy them as a unit that will sit on a desk, and plug into a hifi system. Ask about them at your local shop.
Example: http://www.richersounds.com/product/...id10-ipod-dock
You could probably take the cover off and mount it yourself.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 10th August 2009, 11:15 AM   #4
h@kan's Avatar
I found another one on ebay . Handy with a remote I guess.
I added some stuffing in the first two sections and I think this will be the final stuffing.
Old 22nd August 2009, 08:34 AM   #5
h@kan's Avatar
Some more work done.
No ipod dock yet though...
Added some cheapo ribbon tweeters ($5 on ebay) crossed over with only a capacitor. They actually sound really good! I use them to help 10000hz and over and for that they are perfect.
I wonder how low you can push a 3 inch driver?
This driver has a Fs of around 80hz and this system delivers 45hz at resonable spl.
Regards Håkan
Old 9th November 2009, 04:35 PM   #6
thats a badass speaker like the design
Old 9th November 2009, 05:28 PM   #7
frugal-phile(tm)
planet10's Avatar
H@jen,
That tweeter looks a lot like these ApexJr Ribbon Tweeter.
Living in the baltic, you must have easy access to baltic birch?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th November 2009, 05:44 PM   #8
ianpengelly's Avatar
That is awesome, what a great idea! I suspect it is considerably better than most iPod docks you can buy and in a better finish. Well done.
Old 9th November 2009, 08:21 PM   #9
h@kan's Avatar
Originally Posted by planet10 View Post
H@jen,
dave
It looks like that tweeter for sure! They are quite nice considering that they cost almost nothing. I have tried to cross them at 4khz 12dB but that was not a good idea, I think that they should be used >8-10khz
I live in Sweden (Scandinavia) and that not far from the Baltic states so the need to get the famous "Baltic birch" instead of our own Swedish birch have never crossed my mind. I don't know for a fact but the quality should be almost the same.
Regards H@kan
Old 9th November 2009, 08:51 PM   #10
frugal-phile(tm)
planet10's Avatar
Next time you need a budget tweeter you should also have a look at these from Steve:
Speaker Stuff
I've been buying them 30-50 at a time, really useful for adding some zip on the top of a widebander. Ask Steve for the diyA special price.
We call stuff from Sweden or Finland BB too... should be considerably better than MDF. (i burned enuff MDF on the WE to make 50 of your cute little TLs, more to go)
dave
Pinout for Zune docking connector vs Ipod dock Robert McLean Analogue Source 1 21st June 2010 12:29 PM
New Beginner Project - Ipod Docking amp and speakers baggies01 Chip Amps 17 17th March 2009 08:23 AM
iPod station... car speakers? M3G4 Everything Else 1 7th May 2007 10:05 PM
anyone make an Ipod station? cyborgmexican Everything Else 4 5th February 2007 02:17 PM
New Sonic Impact T24 Ipod Docking Station Tripath07 Class D 3 23rd July 2006 01:40 PM
Page generated in 0.25259 seconds (48.09% PHP - 51.91% MySQL) with 11 queries
