Using four 3 inch tweeters per side (wired in series-parallel) would they be best in a vertical or horizontal lineup?
Are there any rules as to spacing? They'll cross over at 7 kHz. |
#2 |
Do you know their dispersion pattern at that frequency?
#3 |
Inductor,
I wish I did, but these are early (1956) Wharfedale Super 3 tweeters. The Wharfedale factory had a massive fire & lost all their records. They also were sold off for the first of many times. All that's available are SPL/frequency & impedence graphs. They seem to be about 90dB & my main speaker is 95dB. That's why I wound up with four tweeters per side being needed. dobias |
#4 |
I didn't know about the Warfedale fire. What year was that. Information is now in China or something (NPI), it should be kept in bunkers. You know, I don't think it is a good idea, having the tweeters next to each other because of phase issues. It's better to have a good one. Since you have them, why don't you try having them in an arc so they don't interfere so much.
#5 |
Inductor,
Thanks for the opinion for a radial (horizontal) arrangement. The fire isn't mentioned in any of the histories of the Wharfedale company. I only know of it by contacting Wharfedale for speaker information of the early G.A.Briggs speakers. dobias |
#6 |
Good one Troels...
Valuable information about other 3"s also included. http://www.troelsgravesen.dk/super3.htm (Google 1956 Wharfedale Super 3 tweeters) Visit for ideas diyAudio Forums - Visaton FRS8 line array & W170S Visaton FRS8 line array & W170S |
#7 | |
Line array white paper: http://www.audioroundtable.com/misc/nflawp.pdf GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#8 |
Thank you, gentlemen.
The information you've posted for me is appreciated. It was just what I was looking for. dobias |
| Vertical/Horizontal 2 x JXR6 Linear Array as central speaker ? | fvaille | Full Range | 6 | 11th January 2009 11:20 PM |
| Vertical MT, horizontal woofer | fb | Multi-Way | 5 | 14th October 2008 10:55 PM |
| Horizontal vs. Vertical Alignment | Pano | Multi-Way | 2 | 12th November 2006 10:14 AM |
| lateral vs vertical,P vs N | Leolabs | Pass Labs | 3 | 15th February 2005 07:01 PM |
| Page generated in 0.09915 seconds (78.24% PHP - 21.76% MySQL) with 10 queries |
