Old 9th August 2009, 01:37 AM   #1
Default Accounting for Room Lift
When considering a new design, how much consideration should be given to room lift? Should one intentionally design a droop in the response to account for room lift?
Old 9th August 2009, 04:28 AM   #2
jamikl is offline jamikl  Australia
My understanding Trapshooter is that what you ask is correct. There is a chart somewhere, I think by Martin Colloms, that shows the room lift for an "average" British sitting room. As he was probably higher paid than a lot of people in that country his view of what is an average sized room could be a bit larger than what we see on TV programs. I certainly hope that it will have some effect on the speakers I am working out at the moment.
I think this is a good question and am surprised that you have no replies as yet. Perhaps it is not esoteric enough to involve those knowledgeable people who get involved in threads that go on forever, go nowhere and never reach any form of consensus that could be useful to those of us who " don't know as much!"
jamikl
Old 9th August 2009, 04:31 AM   #3
Brett's Avatar
Presenting, 'The Colloms Curve'.
Old 9th August 2009, 06:09 AM   #4
Shaun is offline Shaun  South Africa
Shaun's Avatar
This curve is all but useless, as the boundary reinforcement will change, depending on where the speakers are placed and, as has been pointed out above, the size of the room. DIY allows one to tailor a speaker's frequency response to suit the room.
See here http://www.pvconsultants.com/audio/reflection/rrc.htm
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 9th August 2009, 06:17 AM   #5
Brett's Avatar
I agree, I just posted what the other person asked for. I measure rather than rely on something generic like that.
Old 9th August 2009, 07:00 AM   #6
Shaun's Avatar
I somewhat regret having said "useless", as it at least gives a general idea of how low frequencies are reinforced. But still, actual response of a specific room and placemnt therein will likely be very different.
Shaun Onverwacht
Old 9th August 2009, 07:05 AM   #7
Brett's Avatar
The quote above is all I've ever taken the curve to mean, ie I agree with you that it's an indicator only and each room and speaker position will give a different response. Cheers
Old 9th August 2009, 07:18 AM   #8
macka's Avatar
Phillips did a compehensive study a long time ago that was published in their diy handbook.
There are a set of known response permutations depending on the location of the loudspeaker in an X, Y, Z set of co ordinates.
What I did was look at those published data curves and the modified the Colloms curve based on where the woofer in my design was likely to be located and saved in Bassbox 5.1 as a room curve.
What I found was that by tuning a particular driver with banana curve a certain set of Fs and QTS I was able on paper to get a smooth response with extension from the room where the box was near the front wall and the woofer about 2 feet off the floor.
Bassbox 5.1 has an extended tuning that does this as a custom design. The result is a Fb tuning close to the Fs and a somewhat larger box.
Typically a maximally flat QB3 response will peak in the 50- 100 hertz region (reflect) unless it is placed 1 metre from the front wall and raised off the floor.
This is not always a convenient location in a domestic setting.
Old 9th August 2009, 07:37 AM   #9
Shaun's Avatar
Dunno the situation there in OZ, but over here the average-sized house is getting more and more compact. Seems to me the most common (forced) placement is close to the front wall, often with one speaker in a corner.
Shaun Onverwacht
Old 9th August 2009, 08:57 AM   #10
Inductor's Avatar
Had to change my 10"/58L speakers from BR to closed enclosure because of that, after a long time simulating BSC. I think I can use BR when PA'ing outside. I had them on the floor away from walls and I din't use the inductors/xovers yet as it was just a first test. That Martin Colloms curve makes a lot of sense.
Nasty Room Resonances in New Listening Room TubeHead Johnny Multi-Way 4 23rd May 2009 11:13 PM
Motorized projector lift (scissor lift?) JRace Everything Else 5 7th January 2008 03:11 AM
how do I lift/not lift earth frank2395 Pass Labs 30 31st May 2005 07:38 AM
flat subs and room lift Bill Fitzpatrick Subwoofers 11 17th December 2004 08:23 PM
Lift off LRRockBox Solid State 1 12th June 2004 06:12 PM
Page generated in 0.14129 seconds (68.58% PHP - 31.42% MySQL) with 11 queries
