Old 4th August 2009, 02:31 AM   #1
Default Driver design
I want to design a good mid or bass driver. Does anyone know any resources online or have any tips on designing drivers?
thanks in advance!
Old 4th August 2009, 10:23 AM   #2
el`Ol is offline el`Ol  Germany
I have come quite far with a concept for an FAL-style flat driver but never realized it.
http://www.sibatech.co.jp
http://www.fal.gr.jp
If you are happy with such a driver I will share my ideas here.
Old 4th August 2009, 08:49 PM   #3
sdclc126's Avatar
My question is why do you want to design your own driver?
Soft Dome
Old 4th August 2009, 09:56 PM   #4
GM is offline GM  United States
GM's Avatar
Got a well stocked library? This may help:
Loudspeaker Handbook
John M. Eargle
Chapman & Hall 1997
ISBN 0-412-09721-4
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th August 2009, 01:26 AM   #5
I wonder how good the sound would be making something like these,
Infraplanar: http://infraplanar.free.fr/infraplanar-english.htm
Podium: http://www.6moons.com/audioreviews/podium/1.html
Using old drivers, fill up the cone with polystyrene foam & clamp them to a piece of ply…???
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 5th August 2009, 01:37 AM   #6
thanks for the links and info guys, i will definitely look into it. i thought that there wouldn't be many people here with in depth knowledge of driver design but looks like i was wrong.
why would i want to design a driver? well, it just amazes me how a few basic components can make such different results and i want to find which claims by those manufacturers are even remotely true.
for example, does a minimal rear basket really reduce reflections? i don't know. i probably can't try this out because i can't custom make moulded plastic or metal parts. but i'll try the most i can do.
anyway, thanks again, and if you guys got any more ideas, keep posting!
Old 5th August 2009, 01:53 AM   #7
sdclc126's Avatar
Originally posted by auriches
...why would i want to design a driver? well, it just amazes me how a few basic components can make such different results and i want to find which claims by those manufacturers are even remotely true...
That would take a lot of work. If you're looking to build a nice sounding speaker system you're better off using existing drivers that are well reviewed and tested - others have already done your work for you. Nothing personal but your chances of coming up with something comparable to good existing drivers is not very good.
Soft Dome
Old 5th August 2009, 02:41 AM   #8
CLS is offline CLS  Taiwan
You may try this in the other way round by treating a pressed steel frame which comes with large flat 'spokes'.
Some wool felt or the likes applied on the inner side of that basket can absorb some of the mid-high frequncy reflection. You may hear and measure this effect (especially on those wide range drivers).
OK, this might not be a 'direct' evidence to <a minimal rear basket really reduce reflections>, but pretty much, I think. (I haven't tried modifying midbass or woofers in such way, though.... )
So, maybe there're already many things to by modifying existing drivers before designing a new one from scratch.
Old 5th August 2009, 09:29 AM   #9
commonly the basket frame is made of hard reflective material (steel or whatever), and i would therefore need to add that type of material to the back of existing drivers to test. if i added any absorptive material it would most definitely affect the mids/treble.
Old 5th August 2009, 10:12 AM   #10
Oh! Yes, of course. I just didn't think of that
OK, let's drop that basket 'issue', since it's relatively 'easy' compared to other problems, like cone composition/profile, suspension(s), and the most important (I think) -- the motor.
Maybe it's a good start by studying the works of AE, 18sound, Steallus... etc. Wait, am I repeating what sdclc126 just said?
multiple driver HT sub ..how to design ? JinMTVT Subwoofers 78 4th September 2007 04:56 AM
Best driver for an experimental design BMD Full Range 12 12th May 2006 11:30 PM
The Sub driver design or You Can Do It ZuMbAiU Subwoofers 8 28th January 2006 10:41 AM
Driver Design vs Performance goskers Multi-Way 1 10th August 2005 04:29 AM
Page generated in 0.11537 seconds (79.85% PHP - 20.15% MySQL) with 10 queries
