Do I need a Zobel ?
Do I need a Zobel ?
Old 3rd August 2009, 09:18 PM   #1
chasingame is offline chasingame  United States
Default Do I need a Zobel ?
I have read and studied that the Zobel will create a flat impedence curve making the XO circuit perform as designed.
How do you decide if it is warranted to have a Zobel on either tweeter or woofer ?
I would assume that if your XO point is suficiently high on the tweeter (above the resonance freq) then you may not need one?
On the woofer, would you say that if you XO point is low enough such that there is little rise in the eimpedence at that point you can get away with out it ?
Thanks in advance.
Old 3rd August 2009, 09:23 PM   #2
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
The most compelling reason to use a zobel on a passive crossover network is to provide a flat impedance as seen by the amplifier. Especially with tube outputs with little to no feedback, performance of the amplifier is optimized with a flat impedance vs frequency.
That's my understanding.
Old 3rd August 2009, 09:37 PM   #3
Suppose I have a woofer whos impedence curve rises as the frequency rises (I think this is typical). Suppose that I choose an XO point far to the right within that area.
Also, suppose I have not used a Zobel circuit.
What is the effect? Will volume increase as the frequency increases towards the XO point?
Old 3rd August 2009, 09:56 PM   #4
Geek is offline Geek
Geek's Avatar
I've never bothered to Zobel a woofer, just choose a woofer that doesn't have a skyrocketing impedance at resonance.
Now midtweeters can be a problem that most people overlook/ignore... you don't want an "near-unloaded" tubeamp at HF
Cheers!
Old 3rd August 2009, 09:58 PM   #5
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Do I need a Zobel ?
Zobels don't help with impedance rise at resonance, only the rise above resonance which is due to the inductance of the voicecoil.
You "decide" if it's warranted by looking/measuring the impedance curve and acoustic output and playing about with the crossover.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 3rd August 2009, 10:32 PM   #6
cbdb is offline cbdb  Canada
I thought the Zobel was to help keep the amp stable by ensureing a more constant load for the amp. So if you remove the Zobel your amp might start ringing or even go into oscillation and burn up.
Old 3rd August 2009, 10:47 PM   #7
Here is an impedance curve I pulled of some website... I drew a red arrow at my proposed XO point. I can see that the impedance is rising here but my XO will also be dropping the output off at 12DB.
Will this counteract any negatives of this rise in this region ?
Old 3rd August 2009, 11:49 PM   #8
5th element is offline 5th element  United Kingdom
5th element's Avatar
As has been mentioned before, a zobel network is used to counteract the impedance rise created by the inductance of the voice coil.
A zobel network is basically another tool a designer has available to help them to shape the acoustic output of the driver via the crossover.
If you need one or not depends on the driver/s being used.
That being said, textbook crossover calculators assume a perfectly flat impedance and perfectly flat frequency response.
If you were working with a wide bandwidth driver that was reasonably flat..
http://www.tymphany.com/832873
..one of those for example. And you decided you wanted your crossover frequency to be at 2khz. Obviously this drivers frequency response extends well beyond that point. If you were to put a text book 4th order electrical slope into practice, you'd end up reasonably close to your desired 4th order acoustic goal.
But you can go one step further and that's to apply a zobel network across the drivers terminals. The effect will be to flatten the drivers rising impedance thus making the text book crossover see the impedance it was designed to work with as well as a flat frequency response, getting you one step closer to your goal.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 3rd August 2009, 11:56 PM   #9
Did it Himself
Do I need a Zobel ?
Yes, that is another form of zobel. Different from the one in the topic here.
Old 4th August 2009, 02:08 AM   #10
What are the negatives of using the zobel ?
Do I need a Zobel ?Hide this!Advertise here!
Zobel Or No Zobel ? east electronics Solid State 86 22nd October 2017 10:56 AM
which cap do you like in zobel ? sandro600 Solid State 2 28th January 2007 10:36 AM
zobel Streets97f Subwoofers 4 19th November 2006 04:44 AM
the zobel bigpanda Solid State 9 13th May 2006 03:56 PM
