Old 3rd August 2009, 02:00 AM   #1
Moondog55's Avatar
Default Interconnects
Query here as we don't have an interconnect subsection.
I need to split the output from my Behringer CX2310 electronic XO to drive two stereo subwoofer amps.
Should I follow the directions in the Behringer manual and connect Cold and shield at the XLR connector OR should I follow the advice on D Self web page and connect the Cold and shield at the RCA end
http://www.dself.dsl.pipex.com/ampin...balanced.htm#6
I am battling to get rid of the earth hum and want to keep any introduced noise to the minimum
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 3rd August 2009, 02:36 AM   #2
infinia is offline infinia  United States
infinia's Avatar
This is just a general guide that works 90% as every system is unique.
It's best to connect shields of a twisted pair only at the receive end. A single conn. limits ground loop problems, as stray currents tend to flow from one box to another. Shielding is still effective and is referenced to the quieter grounds.
An exception could be if the receive end box has no quiet earth connection and the send box does, then the single shield connection would be made at the sending side only. Even this example could be a problem if the receive end gnd noise is purely common mode.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 3rd August 2009, 03:05 AM   #3
Moondog55's Avatar
Thanx Infinia, I should have been more explicit, I've only got single conductor shielded cable in the drawer, should I go and by twin and shield??
Old 3rd August 2009, 04:25 AM   #4
infinia's Avatar
Yes that's what audio using 3 pin XLR expects. but you could use what you already have. I really don't like any audio signal currents running thru my shields or chassis.
Old 3rd August 2009, 11:09 AM   #5
Moondog55's Avatar
OK; I walked down and bought some 2-core plus shield, a meter of Proel microphone cable and a meter of some lighter weight stuff.
The Proel is much higher quality but I can't get both protective sheaths into the XLRs end as it is designed for a single 6mm cable, and the Proel is already 6mm in diameter> can I trim the sheath off with out any effect on signal?? or should I use the smaller cheap stuff.
In short runs how important is inner conductor size anyway, will the small stuff make any audible difference over 200mm??
http://search.dse.com.au/search?w=sh...e01071d&ts=new
Centre Conductors: 7 x 0.12mm copper, Shielding: 32 x 0.12mm, spiral wrapped, Diameter: 4mm OD, Nom. Capacitance: 210pF/m (Conductor-shield).
Old 3rd August 2009, 06:03 PM   #6
infinia's Avatar
I don't know about the conductor sizes AWG> mm illiterate.
Do you have a ground loop problems "earth hum" with the coax?
What gear has earth connections?
edit> I think Linkwitz has a good diagram of converting XLR to single ended on his DIY mic preamp. (terminates the unused inner signal with the same resistor)
Old 3rd August 2009, 07:53 PM   #7
Moondog55's Avatar
Everything is double insulated except for the XO unit, I use a common power-board for surge protection, the earth hum is definitely from the Behringer unit ( it is probably in need of replacement- they do not age gracefully )
Old 3rd August 2009, 08:01 PM   #8
infinia's Avatar
Hmm that's weird about the Beh. how did you have it Beh. ins/outs hooked up before?
Old 4th August 2009, 05:40 AM   #9
Moondog55's Avatar
It is definitely the XO unit; when I move the dial to around 300/500 the hum completely disappears.
I'll bring in the spare CX unit and hook it up when I finish fixing my broken sewer pipe, I guess I'm just lucky because it just started to pour with rain
Interconnects planarboy Everything Else 0 30th June 2008 12:01 PM
Best Interconnects? Eric_B_C Everything Else 7 2nd January 2007 03:39 AM
DIY Interconnects RyanW Solid State 13 18th December 2006 10:58 AM
DIY Interconnects ralph-bway Everything Else 2 20th October 2003 10:02 PM
Cat 5 interconnects ddatta Everything Else 6 19th March 2001 01:42 PM
Page generated in 0.11071 seconds (81.99% PHP - 18.01% MySQL) with 10 queries
