using one piece of solid wood for an enclosure
Old 6th May 2003, 10:23 PM   #1
Jared is offline Jared
Send a message via AIM to Jared
Default using one piece of solid wood for an enclosure
I was thining about using a maple log I have about 18" diameter and 24" long as a sub enclosure. Does anyone know of a way to get a hole about 15" deep and 13" diameter bored into this without buying expensive tools? So far my only idea is to use a drillbit many many times and a wood chisel to clean it up afterwards. A mostly round but irregular surface might be a good thing on the interior of the enclosure too, right? Will solid hardwood (maple I think) be rigid enough or should I go with a smaller driver and thicker walls? anyone have any links to other projects involving one solid piece of material for the enclosure?
Old 6th May 2003, 10:34 PM   #2
till is offline till
Banned
simple way is chain saw. Other way is larger bandsaw. I build little boxes this way to sell them. Will make a pic tomorrow and post it...
Old 6th May 2003, 10:43 PM   #3
but I dont want to cut the wood at al, just make a hole in it deep enough to provide the needed enclosure volume.
Old 6th May 2003, 11:00 PM   #4
Banned
with the chain saw it is a little dangerous but possible to make a hole.
With the bandsaw you need to cut throug material you have to glue after you finished.
You cut like this:
Old 6th May 2003, 11:36 PM   #5
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
The easiest and safest way I can think of is to use an Arbortech blade on an angle grinder, they carve wood like nothing on earth and are much safer than a chainsaw.
However you may have problems over time with your log splitting as it dries out, espaecially if you make the walls too thin
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 6th May 2003, 11:41 PM   #6
TNT is offline TNT  Sweden
Hi!
Consider this once more before You put too much effort into it! The DO split / crack for shure. I have seen it myself.
Maybe if You live in a very humid place it is OK!
Old 6th May 2003, 11:48 PM   #7
Banned
it will crack in case you use it not dry enough and put it in the house.
You need to use an piece thats allready dry (some years laying around at a dry place)
The easiest way for a big hole is to find a piece of a tree thats allready has a hole because of illness. If the wall is not to thick and dry slow enough the forces in the material are not so strong and it will have only small cracks.
Old 7th May 2003, 03:43 AM   #8
kneadle is offline kneadle  United States
kneadle's Avatar
Send a message via AIM to kneadle
Michael Barnes at norh carves his initial line of speakers out of a single log.
Old 7th May 2003, 06:23 AM   #9
Kongen is offline Kongen
I think I read somwhere that this kind of enclosure isn't very good when it comes to resonances - something about the vibrations won't be damped as well as in an enclosure made from several pieces of wood glued together... I can't remember where I read it but I believe it was in an article about sonus faber in which it was argued that the multiple pieces glued together as in their speakers keeps vibrations lower than if they used one big piece. I do see the point - to not equally sized pieces of wood - perhaps even different in structure - glued together would help dampen vibrarions due to different resonances of each piece. anyway i'm not a scientist so maybe i'm wrong...
Old 7th May 2003, 07:53 AM   #10
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default solid wood
It is not clear to me why you would want to use a single log this way. Surely it will have asthetic appeal. If you however do it from a point of construction strenght, be aware that a conventional, well-glued joint generally is STRONGER than the wood itself.
Jan Didden
using one piece of solid wood for an enclosureHide this!Advertise here!
MDF vs solid wood polvoson Multi-Way 34 18th November 2016 01:28 AM
Solid Wood? Lewis Moon Multi-Way 15 29th September 2008 10:06 PM
Solid Wood Plinth jlsem Analogue Source 2 3rd August 2007 12:22 AM
How to duplicate a free handed wood piece azira Everything Else 5 19th April 2004 09:01 PM
Copyright ©1999-2017 diyAudio
