#11 |
Banned
aside from the aesthetical value, we donīt need much strength in the construction because it doesnīt take any force like a constructive part when building a house. What we need is a sealed box, and not to much resonace in the band the speaker should be used in. The massive block will be possible to seale from inside, and you are enabled to make a part with very thick walls and high mass. Thick walls means good dampening and high mass is advanageous too. I think the problem is to find a really good pieve of wood, else the idea is fine.
#12 |
Banned
cut with bandsaw
#13 | |
Jan Didden |
#14 |
yes, the main idea was to preserve the incredible color sworls n the growth rings of this particular log. I am not too overly concerned about eh sound quality for a home theatre subwoofer, so long as it is still better than commercial mass market crap. I wold asume that an 80 lb piece of wood would have enough mass to not resonate too strongly in the 10-100hz range?
till - now that I think about it, I have sen the guy who actually vut this og for me do some plunge cutting with his chainsaw and not have it kick back. It is definately not something I want to try. It is just time tho, so I will give it a shot with a 1 icnh wood drill bit and the drill press. If it splits it will be disapointing, but I can just glue it back together and deal with it. |
| Solid Wood? | Lewis Moon | Multi-Way | 15 | 29th September 2008 09:06 PM |
| Solid Wood Plinth | jlsem | Analogue Source | 2 | 2nd August 2007 11:22 PM |
| MDF vs solid wood | polvoson | Multi-Way | 28 | 8th June 2006 04:40 PM |
| How to duplicate a free handed wood piece | azira | Everything Else | 5 | 19th April 2004 08:01 PM |
