Old 31st July 2009, 01:21 AM   #1
Default Refinishing MDF..advice?
So I have a set of speakers/stands that i want to strip and refinish using MJL21193's method, SB urethane primer, rustoleum black then most likely varathane diamond WB poly.
The paint job on them now is SW oil based primer/color and a very unsuccessful brushed on lacquer top coat.. oh and the raw mdf was sealed with shellac.
Any helpful hints on removing the current finish? besides lots of heavy sanding...
Old 31st July 2009, 02:36 AM   #2
infinia is offline infinia  United States
infinia's Avatar
I wouldnt sand to remove the last paint job... just to make thing smooth and ready adhere the next primer.
sanding > SW oil primer> sanding
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 2nd August 2009, 06:48 AM   #3
Stuey is offline Stuey  Australia
Or you could use one of the many paint strippers available, and a scraper, being careful not to mar the surface.
Old 3rd August 2009, 01:49 AM   #4
About the paint strippers, thats kind of why i was asking. Is methylene chloride safe to use on mdf? Mdf is not the usual suspect so to speak. just dont go overboard i guess.
Old 3rd August 2009, 02:12 AM   #5
infinia's Avatar
Why must the old paint be removed? It just adds more work and toxic stuff. FYI modern paint strippers use WATER as part of the removing/clean up process.
Old 3rd August 2009, 02:19 AM   #6
no real reason just me being neurotic.. I will check it out and if its too much work I will just flat sand it.
Just say no to water, thanks for the heads up.
Old 3rd August 2009, 10:06 AM   #7
I agree about not removing the old, but Tech asked about stripping. The paint, that is.
refinishing Tad et-703 e679 Multi-Way 0 12th October 2008 12:45 PM
Refinishing a burned cabinet Empty Set Instruments and Amps 18 16th September 2008 03:56 PM
Need Some Advice?!?!? Cod1628 Car Audio 11 10th December 2007 10:24 PM
refinishing guitar 9am53 Instruments and Amps 3 2nd June 2006 02:38 AM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
Page generated in 0.06887 seconds (80.53% PHP - 19.47% MySQL) with 10 queries
