Anybody out there who knows how the " Aperture Bass Propagation technology" works, mentioned here:
http://www.emeraldphysics.com/page9/page9.html |
#2 |
Based on the pic, it looks like they're doing one of two things:
#3 |
Judged by the size of this hole in front of the woofers, it should have no effect at all in the passband of the woofer.
The "Aperture Bass Propagation technology" works by impressing the customer with fancy words and by this raising the amount of money he will spend for the speaker. In its own way, this is an impressive technology. |
#4 |
I know so much that it works as a dipole, no rear chamber.
I've done some simulating in Lspcad, as a dipole radiator on rear side of cone and a small box, 4 liters, with a short, 30mm port with 100 mm diam. on the front side of the cone. The simulated results can make a grown man cry...... |
#5 | |
A fifteen inch woofer's directivity will begin to narrow at 900hz, due to the diaphragms dimensions. My Summas take advantage of this to cross over to a waveguide which goes down to... you guessed it, 900hz. By re-directing the energy of the fifteen inch woofer through a 6" port, the woofer will now begin to narrow at 2250khz. This change in the directivity allows the woofer to have a more consistent coverage pattern below AND above the crossover point. Pretty clever I'd say. |
#6 |
Hi, is there any measurements of Emerald Physics products out there? CS2 lets say...
http://gainphile.blogspot.com |
#7 |
I'm at work and can't sim this now. It seems to be the same as a slot loaded box without the box. Could be modelled in Horn response with no rear chamber, front chamber same as speaker volume on inside of cone and surround and a conical horn with maybe 25mm length and no expansion. Might look good until combined response is done for back to front cancellation. I have been looking at slot loading an open baffle myself to keep the directivity higher. As I said, can sometimes look good until the cancellation comes into the sim.
jamikl |
#8 | |
#9 | |
#10 | |
| The Physics of Speakers | gmu | Multi-Way | 7 | 18th July 2009 03:34 AM |
| Physics question! | Nappylady | Multi-Way | 3 | 13th May 2005 01:29 AM |
| PWM amp from 'Power Physics'? | IanS | Class D | 2 | 13th December 2004 10:31 PM |
| physics equations | slackerbob | Multi-Way | 22 | 15th November 2003 11:49 AM |
| quatum physics help | theChris | Everything Else | 15 | 1st May 2003 04:41 AM |
| Page generated in 0.11170 seconds (79.20% PHP - 20.80% MySQL) with 11 queries |
