Emerald Physics
Emerald Physics
Old 31st July 2009, 02:42 PM   #11
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally posted by MaVo
You have to take into account that this box uses a 12 inch coaxial driver for mid, so the crossover point will be probably 3 octaves below this 2250hz and thats why the holes wont have much effect.
If that's the case, then my first guess, in post #2 makes sense.
The designer is using a chamber in front of the woofer to roll off the highs, just like a bandpass box.
That's quite clever I think - he's getting the dipole radiation pattern of a dipole, along with the distortion-filtering aspects of a bandpass.
Let's do the math real quick, to see if my hunch is valid.
To figure out the tuning frequency of the chamber, we use this formula:
(2 * fs) / qes
for an Eminence Alpha 15A, that's (82 hz / 1.53 ) = 53.59hz
http://www.parts-express.com/pe/show...number=290-407
And then you tune the backchamber to that frequency.
But there IS NO backchamber. So the Fb of the backchamber is the same as the Fs of the woofer which is...
41hz.
So yeah, looks like this would work. The Fb is off by a third of an octave, but that won't make much of a difference.
Old 31st July 2009, 03:42 PM   #12
dlneubec is offline dlneubec  United States
FYI, The specs say the woofers to mid crossover is at 100hz (LR8-DSP active) and the mid to tweet is at 900hz (BW3-passive).
Dan N.
Old 31st July 2009, 03:48 PM   #13
Godzilla is offline Godzilla  United States
Godzilla's Avatar
>>> The "Aperture Bass Propagation technology" works by impressing the customer with fancy words and by this raising the amount of money he will spend for the speaker. In its own way, this is an impressive technology.
LOL... i don't see where the other driver is?
Godzilla
Old 31st July 2009, 05:05 PM   #14
Originally posted by jamikl
I'm at work and can't sim this now. It seems to be the same as a slot loaded box without the box. Could be modelled in Horn response with no rear chamber, front chamber same as speaker volume on inside of cone and surround and a conical horn with maybe 25mm length and no expansion. Might look good until combined response is done for back to front cancellation. I have been looking at slot loading an open baffle myself to keep the directivity higher. As I said, can sometimes look good until the cancellation comes into the sim.
jamikl
I modeled it a different way. I modeled it as if the enclosure was backwards. So there's a ported *rear* chamber, with a six inch port that's one half inch deep. (We don't know the depth, but we can guess.) The volume under the cone should be about 3.3liters. Again, we can only guess. Reducing the volume will change the tuning frequency of the bandpass.
Here's the modeled frequency response.
Old 31st July 2009, 05:06 PM   #15
jamikl
Here's the parameters I used. Note that the "horn" is actually the cone of the woofer itself. It has a diamter of fifteen inches and a depth of 1.5". I also added a baffle that's 20" wide.
Old 31st July 2009, 05:09 PM   #16
I don't know why I didn't think about the obvious reason to use a bandpass chamber in a dipole.
It reduces the excursion!
duh, how did I miss that?
So you tune the front chamber carefully, and you can double or quadruple the power handling, by reducing the excursion.
Old 31st July 2009, 05:12 PM   #17
And a schematic of this strange beast. Cone on the right, coupling chamber on the left. The port is is 6" in diameter by 1/2" in depth. (just guessing based on the pics)
Old 31st July 2009, 05:23 PM   #18
gedlee is offline gedlee  United States
gedlee's Avatar
Hey John
I don't follow the cone excursion reduction. With a 100 Hz LP there will be no effect to the excursion below 100 Hz.
Earl Geddes Gedlee Website
Old 31st July 2009, 05:46 PM   #19
Originally posted by gedlee
Hey John
There's a 48db/octave electronic filter at 100hz.
But the coupling chamber in front of the woofer forms a physical lowpass. If they tuned it at ((2 * FS) / qes), then the reduction in excursion would occur at 53.59hz.
So that seems quite clever. You get a reduction in excursion at the tuning frequency, a reduction in 2nd and 3rd harmonic distortion, and a dipole radiation patterns.
If you're into dipoles, this seems like a serious improvement.
Old 1st August 2009, 08:58 AM   #20
cnclld is offline cnclld  Finland
How much does this affect the front response below the xo point versus the rear? I guess that could lead to a very strange radiation pattern (not a dipole).
Emerald PhysicsHide this!Advertise here!
The Physics of Speakers gmu Multi-Way 7 18th July 2009 03:34 AM
Physics question! Nappylady Multi-Way 3 13th May 2005 01:29 AM
PWM amp from 'Power Physics'? IanS Class D 2 13th December 2004 10:31 PM
physics equations slackerbob Multi-Way 22 15th November 2003 11:49 AM
quatum physics help theChris Everything Else 15 1st May 2003 04:41 AM
