Old 30th July 2009, 03:13 AM   #1
cuibono is offline cuibono  United States
cuibono's Avatar
Default How to determine power input with shaped toneburst?
I'd like to use shaped tonebursts to determine the point where my driver starts clipping - which I learned about here (most of the way down):
http://www.linkwitzlab.com/sys_test.htm
But I don't know how to determine how much power I'm putting into the speaker because I don't know what voltage to use (the Vpp of the toneburst is constantly changing)...
Anyone know?
"rule of thumb" used to determine xxVA for a power supply's transformer? CopyofAudiófilo Chip Amps 11 22nd July 2008 12:01 PM
Old Rotel Power Amp power input change Elrin Solid State 7 18th September 2005 07:09 AM
ST shaped tube Original Burnedfingers Tubes / Valves 7 13th June 2005 02:02 AM
Shaped PCBs jonclancy Everything Else 12 4th August 2003 07:28 PM
cube shaped sub box hunter Multi-Way 6 12th September 2002 05:11 AM
Page generated in 0.06575 seconds (70.74% PHP - 29.26% MySQL) with 10 queries
