Hi I have been experimenting with active crossovers for my new line array open baffles, ribbon tweeters and subs. I notice that linkwitz seems to be using salen-key topology filters as is every other active filter used for crossover I have seen:
http://www.linkwitzlab.com/filters.htm#3 however the state variable filter seems to be supirior as it outputs LP and HP functions at the same center frequancy so mismatch between the LP and HP filters is eliminated. I have attached a simulation of a 4th order State variable 4Khz crossover that has pi phase shift added to the lowpass output to allow both drivers to be in phase. It was designed using analogs filter tool: http://www.analog.com/en/design-tool...urces/fca.html According to Wikipedia the group delay is several orders of magnitude below the threshold of audiability: http://en.wikipedia.org/wiki/Group_delay |
#2 |
Did it Himself
Depending on the Q of the response, you don't always want the resonance frequency to be the same for each filter.
I also don't think that filters not exactly matching is a big problem, there's other - bigger - influences.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
| active crossover state variable filter | les winter | Multi-Way | 0 | 23rd June 2009 01:31 PM |
| variable infrasonic filter | djronbxs | Solid State | 0 | 20th November 2007 09:05 AM |
| Variable center frequency filter | metal | Solid State | 26 | 18th November 2005 08:12 AM |
| Variable frequency low pass filter | pk386 | Chip Amps | 11 | 25th September 2004 01:43 PM |
| Schema for a variable subsonic filter? | Ryssen | Solid State | 0 | 14th February 2004 07:27 PM |
| Page generated in 0.06436 seconds (73.99% PHP - 26.01% MySQL) with 11 queries |
