Old 28th July 2009, 03:07 AM   #1
ddoyle is offline ddoyle  United States
Default Speaker sleuths and driver detectives
These came home with me the other day, I have been unable to find any info. Lable says Eclipse, the tweeter is a Phillips, made in Belgium. Midrange is mounted in a pvc pipe that runs to the back of the cabinet, 117 15 85 518, no name. Woofer 10280 67846, no name. Slanted front baffel design(time aligned?). Another intresting the front and rear are MDF, the sides are solid oak, 3/4 I think. And the rear opening, I was thinking a passive rad, but no signs of anything ever being mounted, just a finish trim ring. Any ideas? thanks..
Dan
Old 9th August 2009, 08:54 PM   #2
well no responses, a few pictures may be of some help. i have done a search, is there a how to guide for posting pics? thanks
dan
Old 9th August 2009, 09:13 PM   #3
frugal-phile(tm)
planet10's Avatar
Pictures will help... mid has a typical Philips code -- is it an octangonal bezel 4.5"?
A picture can be linked to from webspace or you can attach it to the post using the "CHOOSE FILE" button (limit 1000x1000 pixels and 100kB)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th August 2009, 09:45 PM   #4
Thanks Dave, but choose file? I am a bit confused on the adding attachments... The mids are 5" round, paper cones with a rubber surround.
dan
Old 9th August 2009, 09:53 PM   #5
frugal-phile(tm)
planet10's Avatar
see attachment... if you use this donot preview, just submit (that gets you around a big in the board SW.
dave
Old 9th August 2009, 10:24 PM   #6
My control says browse, so if i select a picture, 800x600, says file too large
Old 10th August 2009, 12:55 AM   #7
Here is a link to pictures of all the photos. Most intresting is the rear panel, wide open woofer size hole with a finish ring around it.
http://s201.photobucket.com/albums/a...on=tageditmany
Old 11th August 2009, 02:52 AM   #8
Hello ddoyle, when I clicked on the link you provided, it went to the homepage for the website, not to the specific page(s) of the pictures you posted. Thought you may want to know.
Peace,
Dave
Old 11th August 2009, 03:21 AM   #9
frugal-phile(tm)
planet10's Avatar
I guess the button name must be browser (or platform) specific.
If that is the pixel extent, then the filesize exceeds 100kB.
dave
Old 11th August 2009, 03:25 AM   #10
frugal-phile(tm)
planet10's Avatar
If you look at the URL, i guess that you need to be logged in as "doylefly" to get at the pictures.
dave
DIY speaker driver? hofffam Multi-Way 3 2nd February 2009 05:50 PM
Any tube-sleuths out there know who made these Daystrom tubes? aletheian Tubes / Valves 3 11th September 2006 06:52 PM
5-driver speaker wiring? scone Multi-Way 4 9th November 2004 01:35 PM
Re-use of old speaker driver William Multi-Way 1 24th October 2001 09:51 PM
Page generated in 0.10619 seconds (79.17% PHP - 20.83% MySQL) with 11 queries
