Old 27th July 2009, 12:52 PM   #1
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Default Using different HF units with coaxial drivers
I'm trying some B&C DE 250-8 and DE 500-8 HF units with my Hawthorne Audio Sterling coaxials.
I notice that while the standard HF unit supplied with the Sterlings (ASD1001?) is repelled by the woofer magnet, the B&C units are attracted. Does this have any affect on the operation of either the HF unit, or the woofers?
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 28th July 2009, 05:51 PM   #2
Nuuk's Avatar
Aren't thereany speaker experts on this forum?
Old 28th July 2009, 08:08 PM   #3
chris661's Avatar
The two magnets attracting/repelling probably won't have much effect, but if you want to be sure, put some metal on one of the magnets (the part that faces the other magnet), so it works like shielding. Blutack in place (stops vibration) and give it a go.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 28th July 2009, 09:22 PM   #4
Nuuk's Avatar
Thanks Chris. The DE 500-8's require an aluminium adaptor plate that is bolted to them, and is therefore between them and the woofer magnet.
I asked because I remember using the Ciare 250 with additional magnet and it was supposed to make a difference how the additional magnet was mounted on the Ciare.
Old 29th July 2009, 12:58 AM   #5
infinia is offline infinia  United States
infinia's Avatar
Default Re: Using different HF units with coaxial drivers
The repelling action forces a little more flux into the woofer VC gap so empiracally you get maybe up to 1 dB more sensitivity. Not sure about HF unit but expect similar effects.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 29th July 2009, 08:08 AM   #6
Nuuk's Avatar
Thanks Infinia. I guess as ever, the proof of the pudding is in the eating!
I'll move on and and see if I can integrate the new HF units with the HA woofer.
Old 29th July 2009, 01:07 PM   #7
Nuuk's Avatar
According to B&C, joining the HF unit to the woofer does affect the T&S parameters of both units and you therefore need to measure the units again when they are joined together!
Old 29th July 2009, 04:14 PM   #8
Brett's Avatar
Of course you should measure, then you'll know, but I doubt it's going to be much. On the Scanspeak pages they sell second magnets of the same size for bucking purposes of older drivers that don't have them. The difference calcs out to be ~0.25dB as the second magnet is outside the magnetic circuit and will have little effect.
The attraction/repulsion is most likely due to the magnets being charged in opposite polarity from the factory for whatever reason.
Old 29th July 2009, 09:05 PM   #9
Nuuk's Avatar
When I listen using the existing crossover, it isn't so much the frequency response that is amiss, it's the timing - it's way off!
Old 30th July 2009, 06:11 AM   #10
Brett's Avatar
What do you mean? A physical offset time delay between them?
Coaxial drivers? Bill F. Multi-Way 54 22nd October 2009 02:23 AM
Coaxial Drivers lejaybo Multi-Way 16 28th January 2009 04:03 PM
coaxial drivers nbcaudio Full Range 4 18th February 2005 06:34 PM
Coaxial direct radiator/compression driver units... 454Casull Multi-Way 6 10th September 2004 04:39 AM
Coaxial drivers... 454Casull Multi-Way 7 8th August 2004 02:17 PM
Page generated in 0.09659 seconds (87.25% PHP - 12.75% MySQL) with 10 queries
