Came across these drivers when looking for a bit more unusual 10" drivers that might work up to about 800-1000Hz.
The SPH-265 seems like a really good classical paper cone driver, and it's been around for a long time, while SPH-250CTC is a bit more heavy duty. Did a search here and in google and ended up with almost nothing, mostly only opinions about use as pure woofer or subwoofer, so I would love to hear how they perform in the midrange. Thought of trying either one of these crossed over to some Neo8 planars and Fountek Neocd smaller tweeter. Drivers will be placed in a box and crossover through a dcx-2496. |
#2 |
Klang & Ton 4/2001 did a test on 25cm drivers, including the SPH-265. I contacted the magazine, but have got no reply about it, and their webshop doesn't have this issue. Maybe someone could supply a scan of this article?
#3 |
I would invest on the SPH-250CTC because of better construction (chassis). On paper seems to be good/fair, with some BSC included. Might be a good choice.
#4 |
hello.
...........found something. greetings........... |
#5 |
I've heard both (I own SPH-265), the 250CTC is used in "Monacor Pro Domo" as a side subwoofer and sounds very dry, deep and punchy in this application. SPH-265 is more "hifi" to my taste, but can recommend both. If there is more room I'd consider this SP-12A/302PA also and SP-8/150PRO for better directivity. Regards, Micha |
#6 |
Thanks very much all for the replies, this is enlightening.
Initially I had some plans on finding a driver no larger than 28-29 cm on the outside, as I have some left over branch-free pinewood that can be used about that wide..but I might go for a completely different box if I find the right driver. The SPH-265 does seem to have that rise of K3 around 1000hz as so many other drivers, how evident it will be crossed over to the planar is another matter. I had a look at the SP-8/150 PRO, it measured quite good in Klang&Ton. This PA stuff is the kind I'd like to try, high sensitivity and light cones, only problem is the low frequency extension. Any further suggestions for a 10-12 inch driver, or maybe 8" (two per speaker) would be welcome. I'd like to try not so common drivers. My price limit is a maximum of 180€ in total. By the way, in Europe Monacors can be had at a fairly cheap price from http://www.ts-audio.biz |
#7 |
Just xing information from same subject
(diyAudio Forums - Precision Devices 12" woofers) http://www.diyaudio.com/forums/showt...86#post1891786 |
| What about Monacor? | mr_push_pull | Multi-Way | 8 | 17th October 2010 10:41 PM |
| BIB or TL with Monacor SPH-170 and DT-254? | jaste | Full Range | 0 | 30th October 2008 01:36 PM |
| Monacor MSH-115 (116) | Michail Bugaria | Multi-Way | 5 | 16th May 2006 07:45 AM |
| monacor | goran14 | Multi-Way | 2 | 20th April 2005 02:12 PM |
| Monacor | mik | Multi-Way | 0 | 16th January 2002 03:51 PM |
| Page generated in 0.09227 seconds (77.01% PHP - 22.99% MySQL) with 11 queries |
