Old 25th July 2009, 03:57 PM   #1
Default Crossing near Fs
I am planning to use 3" full range drivers (used as mid) for a 3 way array project. I would like to cross the drivers at their lowest usable frequency to the woofers. The following are the parameters of the drivers
Fs =157, Qts=2.0.
With such a high Qts. How low can I cross to the woofer without any audible anomalies?
Thanks in advance,
Goldy
Audio enthusiast/hobbyist
Old 27th July 2009, 04:12 AM   #2
if you're going OB, sim them in WINISD in a ridiculously large box (say 10000 L), you'll see the sort of response hump you can expect at the low end - but that assumes an infinitely wide baffle, the hump will fall off as baffle width narrows...
If closed box, just sim them in WINISD to see if you get a hump & xover above that, change the box size to deal with it, or use the hump as part of BSC...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 27th July 2009, 10:23 AM   #3
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
There are numerous ways to compensate,but as you haven't shown enough driver data and and suggested enclosure dimensions, its impossible to recommend a compensation circuit or a solution that will do the job properly.
Here is one very simple method to cure a peaking driver where the driver (enclosure) Tf order will move from 2nd to 3rd responce, Picture 1(1):
b
1(1)
Old 27th July 2009, 11:28 AM   #4
Did it Himself
richie00boy's Avatar
If you are going active crossover, simply use the response as one half of a Linkwitz-Riley 4th-order response. Then you just need to add a 2nd-order filter with same Fc and Qc.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Crossing Over Jordan Jim Griffin Multi-Way 33 17th June 2006 01:15 AM
Safe crossing point (6dB/oct) Sony Multi-Way 11 2nd September 2005 03:00 AM
no zero-crossing dissortions in op-amp designs ?!? CrazyChipMan Solid State 10 22nd April 2005 08:08 PM
Crossing to a sub? smbrown Multi-Way 1 6th August 2004 01:10 PM
Page generated in 0.07792 seconds (78.61% PHP - 21.39% MySQL) with 11 queries
