Old 25th July 2009, 04:45 PM   #1
hllchan is offline hllchan  Hong Kong
Send a message via MSN to hllchan
Question CrossOver for Mini AutoGraph Single Drive
Dear all,
I got a repaired drive which is taken out from a mini-autograph. I would like to use it as my HT center speaker. Have a couple of questions to seek for all your advise:-
1) Can I simply connect my speaker cable to the + and - metal plate behind the drive ? (as I plan to use this drive with any woodern cabin)..
2) Someone suggest me to add a 3.3fu foil connected between the HF + and the LF + and simply connect the speaker cable to the power amp... does it work ?
Any other advise on connecting this ??
Many thanks.
Henry
Old 27th July 2009, 04:00 AM   #2
it seems that these used a 1st order HP filter, so what you propose should work; you may have to add a resistor in series with the tweeter if it is too loud compared with the mid-woofer though...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Drive from crossover? Mach5 Multi-Way 6 12th May 2009 07:48 AM
single tube to drive 300ohm headphones sunrise Tubes / Valves 26 10th March 2009 12:09 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Is a single 3886 powerful enough to drive SS 18w-4531 ? 100db Chip Amps 10 13th October 2007 04:02 PM
A single FET to drive a power tube (directely ...from DAC) Antonio Tucci Tubes / Valves 4 25th March 2003 12:21 PM
Page generated in 0.07393 seconds (70.51% PHP - 29.49% MySQL) with 11 queries
