hi,
For school I am building a custom speaker enclosure. I am really after general tips, I have taken screen shots of my designs. http://i148.photobucket.com/albums/s...peakersiso.jpg http://i148.photobucket.com/albums/s...ofspeakers.jpg I need to know how to seal enclosure, and any other essential things I must do. |
#2 |
Soakin' up the Sound!
delichick,
You can seal it by making sure the joints are tight and true and then using some sort of silicone sealant such as RTV on them and speaker gaskets or sealant around the speakers. When they are playing, you shouldn't feel air being pushed out of any seems, which is usually noticeable during bass notes if it's happenning. Other than that, I'd say make sure your baffles and the rest of the enclosure is heavy/dense/thick enough to be completely rigid as the speakers are playing. Others on this forum know a lot more, so hopefully they'll be chiming in soon. Best wishes on your project ! ![]() Mike
#3 | ||
#4 |
just go translam... so much easier IMO.. and you will get a better end result...
#5 |
thanks for the replies so far. I'm new to the whole speaker thing as this is my first build, so I might need things in lamens terms
dimentions are 1.2 meters long, the curved ends have a diameter of 150mm, and the apex it 200mm tall. about 200mm deep. front and back panels are vic ash (hardwood) along with the dividers. the clear section will be perspex. I would love more detail about the sealing arounf the speakers. as the design is see through, everything as so not be an 'eye sore'. |
#6 | |
#7 |
also if it is important I have bought the speakers from jaycar, specifically models CS 2370 x2 and CS2372 (in the jaycar catalog p. 278 and 395 respectively).
both are manufactured by response precision. |
#8 |
Here one of the trans lam (trans lamination)
And yet another trans lam for a friend. |
#9 |
How did you decide on those drivers, and the box volume? -
frankly, they aren't a good combination (co-ax car speakers - you'll end up with comb filtering and little bass), and are expensive. I'd go for CW2196 + CT2005, and ask here for help with the crossover + box size (50L ); you'll end up with a much better sounding & cheaper set of speakers...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#10 |
I usually use some PVA glue to seal the box - just run it around on the inside where the panels meet. If you want it to look nicer, use PVA glue, then, when it's still wet, get some damp kitchen roll, and go along it, so you'll get a 1/4 circle effect.
Around the speakers, a foam gasket works well, or, if it's permanent, silicone will do the job (just make sure it stays where it should). I think I've missed something here - no drivers were mentionned. For drivers, I'd advise Visaton (fairly cheap, reasonable sound), but it all depends on budget. Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
| custom pa speakers | suchuwato | PA Systems | 2 | 7th October 2007 08:58 AM |
| In wall custom speakers | CPopowski | Multi-Way | 4 | 19th March 2007 11:16 AM |
| Custom Budget Speakers | allenclark | Multi-Way | 1 | 30th March 2005 12:18 PM |
| Where can I find A.N. custom speakers? | mark_titano | Multi-Way | 0 | 8th February 2005 06:32 PM |
| Custom wound speakers? | eeka chu | Multi-Way | 7 | 27th November 2004 10:31 AM |
| Page generated in 0.11697 seconds (78.73% PHP - 21.27% MySQL) with 10 queries |
