Old 25th July 2009, 06:24 AM   #1
56oval is offline 56oval  Australia
Default Driver Placement on baffle
Hi Diy
Is it better to have a asymetric driver layout on a baffle .
This is the top section of a 4 way .The bottom driver is a 10" PHL3020 .
Also theres 2 cabs design I'm looking at one has a curved back an the other a triangle shape which would work better or is it much the same .The triangle shape allows me to have more cuts per sheet for a Magico type enclosure .
Cheers
Mal
Old 25th July 2009, 08:10 AM   #2
knorke is offline knorke  Germany
knorke's Avatar
I would say with such rounded corners there is no need
for asymmetric driver pacement.
Old 26th July 2009, 05:25 PM   #3
Thanks Knorke for the reply .
Cheers
driver placement speedie Multi-Way 4 9th August 2009 04:22 AM
BIB DRIVER PLACEMENT n' others herpaw Full Range 18 27th December 2006 08:53 AM
Driver placement on baffle - advice needed TheoM Multi-Way 3 16th September 2005 07:28 PM
Question about baffle placement and box volume piro Multi-Way 21 13th August 2005 03:52 AM
driver placement on front baffle griff Multi-Way 3 5th April 2002 10:51 PM
Page generated in 0.06571 seconds (69.57% PHP - 30.43% MySQL) with 10 queries
