Old 22nd July 2009, 05:04 PM   #1
Default Wave Diffraction & Kharma Loudspeakers
Hi Chaps,
Any thoughts as to the veracity of having a grooved front baffle?
See Link:
http://www.kharma.com/exquisite/khar..._reference.php
Can these grooves aid wave diffraction, if so, in what way?
Many thanks in advance,
T.J.
Old 22nd July 2009, 08:02 PM   #2
MaVo is offline MaVo  Germany
If they were bigger, they would probably be detrimental to sound quality since they would act as edges and produce diffraction. As small as they are, they probably do no harm.
Old 22nd July 2009, 08:31 PM   #3
thadman is offline thadman  United States
I believe a good rule of thumb is that an obstacles dimensions must exceed 1/4 wavelength to have an appreciable effect, otherwise the wave behaves similar to a fluid.
In other words, it appears to be simply aesthetic related.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 3rd August 2009, 07:18 PM   #4
Dear All,
Many thanks to those who have taken the trouble to reply.
T.J.
Mechanical wave diffraction thadman Multi-Way 78 18th September 2009 01:13 AM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Microphone turns triangle wave into square wave? Circlotron Analogue Source 18 25th January 2003 06:44 AM
Page generated in 0.08101 seconds (67.84% PHP - 32.16% MySQL) with 10 queries
