Old 22nd July 2009, 05:08 AM   #1
Default LC Meters, in Australia
I've been searching the stores for a cheap LC Meter & I have found a couple.
The trouble is these meters only measure inductance from 2mH upwards, and I want to build some inductors with values of around 0.6 to 0.9 mH. Do any Aussies know where a suitable meter can be purchased in our fair land at a reasonable price?
Steve
Old 22nd July 2009, 06:01 AM   #2
CLS is offline CLS  Taiwan
How about buying a Woofer Tester?
It's good at measuring inductors. And of course it's a driver impedance tester, so if you keep building speakers, you'll need it anyway.
Search "WT3" in Parts Express.
Old 22nd July 2009, 06:51 AM   #3
Moondog55's Avatar
Jaycar have a couple of DMMs with L C capability; whats your budget
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 22nd July 2009, 07:38 AM   #4
MadMutt is offline MadMutt  Australia
http://www.altronics.com.au/index.as...=item&id=K2533
Same boat, built this.
If you can solder you'll be fine.
Old 22nd July 2009, 07:42 AM   #5
>>Jaycar have a couple of DMMs with L C capability; whats your budget<<
I have seen one Jaycar model, cat # QM 1324,
Inductance, capacitance, Freq, $49 95,
but the inductance starts from 20mH up.
If you can see another jaycar model suitable, post the cat#, thanks.
Another altronics model was about the same price but started at 2.0mH up.
>>>How about buying a Woofer Tester?<<
Doesn't measure capacitance!
Old 22nd July 2009, 07:46 AM   #6
If you can solder you'll be fine.<<
Looks Ok, was it that easy to build ?
Old 22nd July 2009, 07:46 AM   #7
I had that jaycar meter.
Threw it out after two weeks.
Slow and very unreliable.
EDIT, yup, very easy.
Will take some pics if you like.
Old 22nd July 2009, 07:50 AM   #8
Thanks MM, another reason not to buy it.
Pics, yes, that would be good, thanks.
Old 22nd July 2009, 07:59 AM   #9
doing pics now, can send you hig res ones if you want to give me an email...
Ok, here's an internal shot.
So simple.
IGNORE the yellow wires.
The lcd module has a backlight built in, but is not used in the kit.
I like to see what I'm reading in all lighting so I've wired up these back lights.
Old 22nd July 2009, 08:17 AM   #10
Yes, looks easy enough. Pity though it only measures up to 0.8uf.
But the inductance range is good.
VU-meters Cobra2 Swap Meet 3 13th November 2011 08:09 AM
VU Meters Weston Tubes / Valves 15 3rd August 2008 12:45 AM
VU Meters boostin1989 Parts 9 26th April 2006 04:26 PM
Hi from Australia(Bunbury,Western Australia) aer Introductions 1 24th June 2005 03:21 PM
VU meters Kilowatt Solid State 6 12th May 2002 09:31 AM
Page generated in 0.10846 seconds (78.22% PHP - 21.78% MySQL) with 11 queries
