Old 21st July 2009, 05:28 PM   #1
Unhappy bass problem
I have a problem with the bass being louder on one side of my room. My room is 15' X 16'. The ceiling is tapered from 8' to 10'. The corners of the front wall are on a 45 degree angle- 6 foot across. The room is set-up to be very soft with carpet on the floor, acoustical lay-in ceiling, and foam padding on all walls. I have tried everything I know to correct this problem. The woofers have been placed in all different positions and corners. I would appreciate any help.
Thanks, John
Old 21st July 2009, 10:06 PM   #2
Have you tried to model your room? The FRD site has a room modelling tool which I found to be very accurate. You can model one boundary at a time and see the effects then all boundaries.
Old 22nd July 2009, 02:36 AM   #3
gedlee is offline gedlee  United States
First, do you have any measurements or is this just subjective? If it's subjective then I would suggest that it's a mode that is excited and is louder on that side of the room. Try using multiple subs, but better yet, get some measurements and then try multiple subs.
Old 22nd July 2009, 08:21 AM   #4
Inductor's Avatar
Do you think you have a problem of sympathy/reflection at the dominant frequency of the room, w/ceiling, and with the speakers ressonance? And is (it) louder on the higher side of it?
:reflection from ceiling, like in a concert hall
Old 22nd July 2009, 09:53 AM   #5
Elias is offline Elias  Finland
Elias's Avatar
Default Re: bass problem
Hello,
I suspect the problem comes from the room.
Have you tried dipole bass already?
- Elias
Reinventing the wheel !
Free wavelet software for audio analysis click here!
Old 22nd July 2009, 11:28 AM   #6
trevamp is offline trevamp  England
Default Bass problems
You have uneven bass coverage it seems , due to multiple bass sources far apart. I suggest trying an experiment by placing all your bass radiating speakers close together at point I think this will improve matters. It would be best in any case to stick to single point sources siutably rolled off and on in the bass.
Old 22nd July 2009, 02:17 PM   #7
MaVo is offline MaVo  Germany
Five posts and five different ideas on how to solve the problem. If i were new here, i would be confused now.
As a rule of thump, you can assume that "gedlee is allways right".
Old 22nd July 2009, 02:28 PM   #8
MaVO - thanks for the vote of confidence! But this will certainly start a war!!
Stereo bass problem Eriksonas Tubes / Valves 3 18th May 2009 04:01 PM
Bass problem matanss Digital Source 2 23rd May 2008 09:52 AM
Amplifier Bass with problem aguantesoda Solid State 30 16th April 2007 09:34 PM
Bass problem with speakers fossey Car Audio 5 7th July 2005 10:01 AM
problem with bass blockers all_about the12 Car Audio 1 15th October 2004 03:08 PM
Page generated in 0.09388 seconds (81.31% PHP - 18.69% MySQL) with 10 queries
