Old 21st July 2009, 08:25 AM   #1
jamesjung21's Avatar
Default Installing phase plugs on Philips drivers
Hi
I have a couple of questions.
I have a pair of vintage 10" Philips AlNiCo full range drivers and a pair of Planet10's wood phase plugs with 3 screws on the bottom for magnetic mounting.
My original plan was to cut out the dust caps and install the phase plugs, but I recently came across this web page and got me think twice:
Copper cup on Philips pole piece
According to the website, some Philips drivers came with copper cups put on top of pole pieces, and I was wondering if this prevents phase plugs from being installed magnetically.
My drivers have loosely woven (partially see-through, slightly convex rather than concave as in the website example) dust caps, and when I shine white light on dust cap, I think I see copper colour underneath. So I am assuming my drivers also have them.
Someone suggested that the copper cups are probably too thin to affect magnetic mounting, but it would really nice to confirm this.
My second question would be, my drivers are 800 ohm high impedance drivers and I heard they are much more fragile compared to ordinary lower impedance ones. Is it even a good idea to attempt cutting out the dust cap, or would it be too much risk of breaking the fragile (and irreplaceable) voice coils?
Kind regards,
James
Old 21st July 2009, 10:07 AM   #2
chris661's Avatar
Simple. How much do you care about them?
If you care little, go for it, or, even better, get a proffessional to do it for you, then if they mess up, you can claim some form of compensation.
If you care a lot, I, personally, wouldn't do it. You might end up wrecking one of them, so you'd only have one left.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 22nd July 2009, 09:59 AM   #3
Any other opinion?
But how much more sensitive are high impedance drivers compared to ordinary drivers? I need advice from practical experience with this type of drivers, not an in-general advice.
Kind regards,
James
Old 22nd July 2009, 03:36 PM   #4
frugal-phile(tm)
planet10's Avatar
I wouldn't worry about the copper shielding the magnetic strength, but if that copper cap is the shape of the end of the polepiece, you would need a phase plug with a complimentary shape -- mine won't fit, they require a flat-topped pole piece.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Phase Plugs For Single Full Range Drivers thetubeguy1954 Full Range 15 23rd June 2008 10:09 AM
what to use when installing Phase Plugs karma Multi-Way 2 30th December 2005 05:08 PM
DIY phase plugs Aural Dan Multi-Way 0 22nd September 2004 03:33 AM
Phase Plugs levon Multi-Way 33 15th March 2004 12:11 AM
Page generated in 0.07084 seconds (84.75% PHP - 15.25% MySQL) with 10 queries
