L pad placement....
L pad placement....
Old 18th July 2009, 04:24 PM   #1
Big_Bill is offline Big_Bill  United States
Default L pad placement....
Hello gang!
Any suggestions as to the minimal distance (length of jumper wire) one can successfuly use between an L Pad and a Zobel network on the crossover board????
Old 20th July 2009, 01:44 PM   #2
grantnsw is offline grantnsw  Australia
Hi Bill,
'minimal' distance kinda threw me? at audio frequencies, metres should be ok, as long as there's no induced mains hum.
I'm not entirely sure I understand your question but, it is possible for testing purposes to 'LPpad-down' a driver while walking around your listening room. Lyn Olson described his method in his ME(2) designs, from memory. I lost the link so maybe google it or ask him?
When the best setting is found, you simply measure the Lpad's Rs and Rp then solder in the appropriate series and parallel resistors. Amp -> xo -> lpad -> zobel -> driver ( I think the Zobel has to be physically across the driver terminals). my 1/2 cents worth, experts please chime in,
and correct me if I'm wrong please. Grant
Old 20th July 2009, 02:16 PM   #3
activexp is offline activexp  United Kingdom
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
I don't fully understand your question but as far as I know there isn't a 'minimal' distance between an L-pad and Zobel network.
Old 21st July 2009, 08:20 AM   #4
sparkless is offline sparkless  Australia
>>>( I think the Zobel has to be physically across the driver terminals).<<<
No, not necessary.
http://www.diyaudioandvideo.com/Calc...qual/Help.aspx
Old 22nd July 2009, 03:26 AM   #5
Default Clarification
By distance (linear inches, Cm, mm, ect..) I mean the minimal length (on the crossover board) of jumper wire between the Zobel circuit and the L-Pad circuit before the circuits begin to interfere (if at all) with each other.
Thanks, Bill.
Old 22nd July 2009, 11:27 AM   #6
activexp's Avatar
There shouldn't be any interference between an L-pad and Zobel as they're non inductive, so they can be as close together as you like.
Old 22nd July 2009, 03:21 PM   #7
Default Thank you.....
Thanks activexp!
L pad placement....Hide this!Advertise here!
Placement lpd Planars & Exotics 0 20th August 2008 11:39 PM
Opt placement Niila Tubes / Valves 1 20th March 2008 07:04 PM
sub placement chainenoble Subwoofers 3 13th October 2006 03:45 AM
Placement of PR on a sub box Stantob Subwoofers 5 16th January 2006 10:21 PM
