Classic monitor designs?
Old 5th August 2017, 04:19 PM   #511
exurbia is offline exurbia  Australia
exurbia's Avatar
If I didn't have to p#ss fa!t around cropping pictures I would put some up of my krixes.
The Commonwealth, going round and round and.....
Old 5th August 2017, 09:55 PM   #512
Ro808 is offline Ro808  Netherlands
Originally Posted by wesayso View Post
I want it as perfect as I can get it, with a touch of personal preference
Obviously, I am not talking about major deviations from "the ideal", but something along the lines of Troels' tiny XO tweaks by playing around with different resistor values.
Old 5th August 2017, 10:05 PM   #513
Are you familiar with this?
It's a kind of 'Photoshop ultra light' and allows you to easily convert formats, resize etc.
Old 5th August 2017, 10:14 PM   #514
Bigun is offline Bigun  Canada
Bigun's Avatar
I'd rather do that in the drive electronics, somehow that seems a more appropriate place as you can control things at smaller power levels than in the XO.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 13th August 2017, 02:32 AM   #515
system7 is online now system7  United Kingdom
system7's Avatar
This is one of my backburner projects, which I have been playing around with.
This old Monitor Audio MA7 12L reflex box:
It seems to have improved with a bit of run-in. I'm not surprised, because electrolytic capacitors that get no voltage lose their insulating layer over a few months. It's a chemical thing IIRC.
The simulation is not exact, but close enough to tell us what goes on. It, like the classic BBC LS3/5A is a BW3 design. You really ought to know about BW3 in a World that seems obsessed with LR2 and LR4. See, 90 degree BW3 phase is a constant power filter. You can get impedance exactly flat with a bit of effort.
And it sounds good all round the room. No deep nulls above and below axis.
I'm growing to enjoy this paper bass 5" speaker in the near field of a small room. The bass is really very good. And my modelling suggests it (third Order) might work well with the notoriously difficult 6" bass. I have very little time for soft domes, but those old 3/4" mylar tweeters work well. They just don't seem to make 'em any more.
Couple of good driver selections by Troels, not that I'd use his filter ideas. This idea is better, IMO. Classic monitor designs?
Peerless HDS PPB 830860
Vifa PL14WJ-
File Type: png Third Order Theoretical values 3kHz.PNG (18.6 KB, 66 views)
Best Regards from Steve in Portsmouth, UK.
Old 4th September 2017, 08:58 PM   #516
Steve, what is wrong with a proper soft (i.e. silk) dome?
Here's an intering paper on light metals and
alloys, ceramics, CVD diamond, and/or composite materials for cone, dome and surround applications.
Old 5th September 2017, 12:30 AM   #517
system7's Avatar
Since 80-90% of the World's speakers have soft domes, I'd possibly offend a lot of people by suggesting there is a better way of doing things. Nobody wants to hear this sort of thing.
But here's a history lesson. 50 years ago or so, most speakers used 2-3" cone tweeters. And very fine they sounded if implemented well. But they fell off badly off-axis. Very directional, you see. Enter the 1" soft-dome, mainly by Philips. Great dispersion off-axis. But not so musical. Not so engaging into the audio-illusion of the live performance.
I read Robin Marshall years back on rigid metal domes versus soft-domes: Robin Marshall: A Modicum of Genius | Stereophile.com
The problem with soft-domes, IMO, is the centre of the VERY floppy soft-dome plays different tunes from the edge. Sometimes it is moving in the opposite direction from the edge. This, IMO, ADDS distortion, whereas some other types simply dip into silence due to more damping applied.
Back in Robin Marshall's day, ring-radiators were unheard of, but pinning the uncontrolled soft-dome centre seems like a plan if you avoid the more rigid metal types. We now have Vifa XT25 and SB Acoustics soft material ring-radiators, below.
I am forming some theories these days. I think flat impedance is a good thing, especially for cheap amplifiers. And I have built a lot of exotic amplifiers, so I'm no fool about how difficult they can be to keep stable with certain electrical loads. I think BW3 is a good thing that musical types like, who know how live music sounds.
Classic monitors is about the tested ideas that work well. Here's the waterfall plot of a very high-end Morel soft-dome. A lot of nasties there, IMO. I've never had much luck with my similar soft-dome Morel CAT298 tweeters. Everything else worked better. Monacor HT-22/8 Cones and Visaton DT94 Mylar and aluminium SEAS 19 TAF/G included.
Old 5th September 2017, 12:26 PM   #518
Alex M is offline Alex M  Europe
Surely the problem with soft domes is much the same as with midrange drivers, which are mostly used well outside their pistonic range too, and dealing with cone breakup modes is accepted as being critical to clean performance.
That Morel is obviously poorly designed! Here is a waterfall plot (not my measurement) for the SEAS 27TFFC soft dome I used in Troels' 3-Way Classics:
MUCH cleaner than the Morel.
Alex
Old 5th September 2017, 01:15 PM   #519
Zvu is offline Zvu  Serbia
Zvu's Avatar
Here is waterfall for Morel MDT32s from the same guy:
Not for fainthearted
Old 5th September 2017, 02:19 PM   #520
boswald is offline boswald  United States
Look at the time scales. Bad comparison.
Classic monitor designs?Hide this!Advertise here!
Classic 16.0 Lowrider Tubes / Valves 38 6th August 2008 08:15 AM
efficient (loud) 'monitor'/bookshelf designs for 5.1 Puggie Multi-Way 0 30th May 2006 10:17 AM
Classic BR Alignments BAM Multi-Way 0 20th November 2005 04:31 PM
The A4 monitor, best mini monitor? KURT Multi-Way 5 26th April 2005 01:34 PM
