#981 |
I've read the first 30 pages or so and i have just one thing to say
http://www.epolis.lt/cms/100290lt.jpg :P |
#982 |
Speakerholic
Those are ok but I would have put the tweeter just under the mid horn and put them on a 30 cm platform.
#983 |
from what I know such mid horn is crossed relatively high, above 500hz
which means the woofers play quite a lot of midrange thus 2 woofers side by side is bound to be trouble |
#984 |
The inner LF river on the D66000 plays to 700 and the outer is crossed at 150Hz in a .5 arrangement from my reading of the documentation.
#985 |
anyway my point was that if jbl uses this configuration for hi-fi they have o good reason to do that. Large ugly speakers + horn + HFhorn on top. It's more similar to a proaudio setup with a cherry on top rather than a hi-fi one.
Now putting the jokes aside, has anyone here tried to build something similar to the everests? |
#987 |
I would like to build someting like this one, some day
#988 | ||
Sure, I have built several. My current builds contain mostly pro audio drivers seconded for use at home including JBL LF drivers and waveguides. |
#989 | |
www.kta-hifi.net Last edited by kevinkr; 8th January 2011 at 06:19 PM. |
#990 |
I have been going through the process of improving a pair of JBL HLS810's. At first, I decided to pick up a pair of Pyle Pro pds442 compression drivers and compatible horns. Then, left with the horrible fact that the stock 8" woofers were woefully inefficient and lifeless, I decided to take a risk.
A couple days ago, I ordered in some Celestion TF 0818's. I've heard good things about Celestion, however there are few reviews of the 0818's. Their sensitivity (94 db), response curve, and the fact that they are designed for a 2-way system with a small cabinet seems to make them well-suited for my speakers. I'm using a subwoofer that's crossed at around 100hz, so I'm hoping that this system will interface well. LF Pressed Chassis / Ferrite - TF0818 - Celestion - Guitar, Bass & Pro Audio Speakers I'm just hoping that a 2000hz crossover won't kill the magic! I'm intrigued as to how they will sound, so I will keep you guys posted! For $38 with free shipping, I couldn't find a better deal. |
| Fitting drivers in cylinders pros & cons | 56oval | Multi-Way | 5 | 24th February 2009 12:30 AM |
| pros/cons of a 845 VS 211 | jarthel | Tubes / Valves | 2 | 18th June 2007 12:57 PM |
| TL vs MLTL, pros and cons | Tomac | Multi-Way | 5 | 29th December 2004 12:55 PM |
| Filterless DAC - pros and cons? | mr_push_pull | Digital Source | 1 | 11th August 2004 02:56 PM |
| Pros and Cons of this technique? | G | Tubes / Valves | 35 | 23rd October 2003 05:37 PM |
| Page generated in 0.12592 seconds (78.44% PHP - 21.56% MySQL) with 11 queries |
